Topic: Debouncing multiplexed buttons (Read 3273 times) previous topic - next topic
SquishyFish
I've been working on this for hours how and nothing seems to work.
I have a Mayhew Labs Mux Sheild with 16 push buttons on the first Mux. I'm trying to debounce the input, but nothing I've tried seems to work. Here is the code I have:
Code: [Select]
#define CONTROL0 5
#define CONTROL1 4
#define CONTROL2 3
#define CONTROL3 2
int buttonState[16];
int buttonStatePrev[16];
for(int i=0; i < sizeof(buttonState); i++){
    buttonState[i] = 0;
    buttonStatePrev[i] = 0;
pinMode(CONTROL0, OUTPUT);
  pinMode(CONTROL1, OUTPUT);
  pinMode(CONTROL2, OUTPUT);
  pinMode(CONTROL3, OUTPUT);
  MIDI.begin(4);
  //Serial.begin(9600);
  pinMode(14, INPUT);
  pinMode(15, OUTPUT);
  pinMode(16, INPUT);
  digitalWrite(14, HIGH);
  digitalWrite(15, LOW);
  //digitalWrite(16, HIGH);
void loop{
for (int i=0; i < 16; i++)
      buttonStatePrev[i] = buttonState[i];
      buttonState[i] = digitalReadMUX(i);
      //Serial.println(buttonState[i]);
      if (buttonState[i] == 1 && buttonStatePrev[i] == 0) {
        MIDI.sendNoteOn(58-i,127,1);
      } else if(buttonState[i] == 0 && buttonStatePrev[i] == 1){
        MIDI.sendNoteOff(58-i,0,1);
void selectMUXPin(int pin)
    digitalWrite(CONTROL0, pin & 8);
    digitalWrite(CONTROL1, pin & 4);
    digitalWrite(CONTROL2, pin & 2);
    digitalWrite(CONTROL3, pin & 1);
int digitalReadMUX(int pin)
  selectMUXPin(pin);
  return (!digitalRead(14));
I tried importing the Bounce library, declaring a bounce object on pin 14 (the pin of the first mux) and in digitalReadMux return the bounce.read(), but for some reason that just completely destroys the logic - only the button on pin M01 pin 1 seems to be read (the rest do nothing) and the resulting MIDI message consists of 16x noteOn messages followed by 16 noteOff messages.
Can anyone help me out here? I've been at this for hours now, and I'm making absolutely no progress.
SquishyFish
Bump. Can a mod please move this to Multiplexing and LEDs? Might get more help there.
UKHeliBob
Code: [Select]
    buttonState[i] = digitalReadMUX(i);                 //get current button state
    if (buttonState[i] == 1 && buttonStatePrev[i] == 0) //the button state has changed
      buttonStateStart[i] = millis();
      //note the time it changed
    if ((millis() - buttonStateStart[i]) > debounceTime)//has been in this state for some time
      //so do stuff here
      buttonStatePrev[i] = buttonState[i];                //remember the button state
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
SquishyFish
Yes I've seen that, but how do I incorporate this block of code:
Code: [Select]
Its meant to send the NoteOn when state changes from off to on and a NoteOff when its state changes from on to off. It works as is, except for the bouncing issue. When I incorporate your code, it sends nothing.
Code: [Select]
      //so do stuff here
At this point I've tried a thousand variations and I still can't get it to debounce properly; I either get a stream of NoteOns and no NoteOffs, or NoteOn NoteOffs that are still bouncing all over the place.
UKHeliBob
I don't have the hardware to try the multiplexed version using an array of button data but this is a de-bounced button state change program.  Adding the arrays and reading from the multiplexed input should be relatively simple.
Code: [Select]
byte buttonPin = 8;
byte currentButtonState = 0;
byte prevButtonState = 1;
byte wasPrevButtonState = 1;
long buttonStateStart;
long debounceTime = 100;
  pinMode(buttonPin, INPUT_PULLUP);
  currentButtonState = digitalRead(buttonPin);
  if (currentButtonState != prevButtonState)  //button state has changed
    buttonStateStart = millis();  //remember the time of the state changed
    wasPrevButtonState = prevButtonState;
    prevButtonState = currentButtonState;    //ready for the next change check
  if ((millis() - buttonStateStart) > debounceTime)  //has been in this state for some time
    if (currentButtonState == 0  && wasPrevButtonState == 1)
      Serial.println("action 1");
      wasPrevButtonState = currentButtonState;        //stop the action happening again until state changes
    else if (currentButtonState == 1  && wasPrevButtonState == 0)
      Serial.println("action 2");
fungus
Try this:
Code: [Select]
    if ((millis() - buttonStateStart[i]) > debounceTime)// Allow some time to pass between changes
      if (buttonState[i] != buttonStatePrev[i]) //the button state has changed
        if (buttonState[i] == 1) {
        else {
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
SquishyFish
It seems so obvious now, kicking myself! Thank you Fungus!
fungus
I think you can simplify it a bit, use less RAM:
Code: [Select]
      byte b = digitalReadMUX(i);        //get current button state
      if (b != buttonStatePrev[i]) //the button state has changed
        if (b == 1) {
        else {
        buttonStatePrev[i] = b;
