Topic: How can I attach a crank like this to a motor like this? (Read 5264 times) previous topic - next topic
prismspecs
Here is the setup I'm going for:
Here is my motor:
http://www.ebay.com/itm/280875300072?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
What kind of connections do I need to make this happen?
runaway_pancake
Looks like a lot of improvisation (wood, tape, hot-melt glue...)
You can, too!
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
zoomkat
Erdin
They are 1.3V, are you using a 5V Arduino ? Why would you use 1.3V motors ?
They are 18000 rpm, why would you want to wiggle the tail with 18000 rpm ? Is it a very fast fish ?
Can you use a servo ?
kf2qd
Any hobby shops near you that have Model Airplane supplies? They have thins like small shaft collars that are made of brass, and brass plate. You could solder the shaft collar to a piece of brass plate and then (using the set screw in the shaft collar) mount the crank to the motor.
Hey guys - nice of you to offer useful answers and ideas to the question that was asked.... Try to be helpful, not just geniuses...
runaway_pancake
#5
Mar 05, 2013, 07:22 pm Last Edit: Mar 05, 2013, 07:27 pm by Runaway Pancake Reason: 1
You interpreted differently than "we" did.
That's OK.
If he wanted to do it like the picture, we gave our take on that ("Improvise, that's how we won the war.")
Anybody can go spend money.
> > > I *heart* JBWeld !
prismspecs
Thanks for the tips. I guess a big question I have that I didn't explicitly ask is: how do you attach things to the motor shaft (or whatever the rod sticking out of it is called)?? It is totally smooth so it doesn't make sense to me how one would connect something. I would also love to just extend the rod like 8 inches (shuttup) so how would I do that? Do I remove the shaft that is already there and replace it or is there an adapter?
runaway_pancake
Thanks for the tips. I guess a big question I have that I didn't explicitly ask is: how do you attach things to the motor shaft (or whatever the rod sticking out of it is called)?? It is totally smooth so it doesn't make sense to me how one would connect something. [...] Do I remove the shaft that is already there and replace it or is there an adapter?
The drawing at the ebay link shows the shaft diameter is "0.8"
I guess it's the French system (mm)
Most couplers (hubs, bushings) I've seen are for 2mm, 3mm, 4mm
http://banebots.com/c/WHB-HM-HS4
Erni
#8
Mar 06, 2013, 04:21 pm Last Edit: Mar 06, 2013, 04:23 pm by Erni Reason: 1
These small motors (called pager motors) are used in micro airplanes, and usually the propellor is just a press to fit solution.
Make a 0.5 mm hole in the material you want to use, and press it on the shaft.
:D
A good one, I think the only country still using Inches is  USA   XD
jackrae
If you are not transmitting a lot of torque you could actually use a short length of fine bore rubber tubing as a shaft coupling. If necessary a small drop of super-glue can be put into the tube bore to enhance the grip  -  just make sure it doesn't get into the motor internals !
cr0sh
If you were really crafty, and had a way to keep the shaft from turning (or could remove the armature from the motor), you could thread the shaft with the right miniature die (you could probably find a miniature tap and die set here: http://www.micromark.com/). Then, tap the part you're wanting to mount, and thread it on (maybe with a small bit of thread lock).
MarkT
:D
Well the UK is mainly switched to metric in technical/engineering areas now except for legacy applications,
but things like beer units and road speed are still imperial (political conservatism).  People
commonly use a mix of metric and imperial in everyday use now.  SI will prevail everywhere in the long term I
think just because
1 - The convenience of almost no conversion factors needed (consider calculating horse-power from torque
     in foot-pounds and RPM - in SI power = torque * frequency * 2pi
2  The fact electrical units are already SI and directly tied to the metre/newton/joule/watt.  For instance farads
    are a shorthand for columbs-squared-per-joule, volts are watts-per-amp, volts-per-metre = newtons-per-coulomb.
michinyon
