Loading...
Pages: [1]   Go Down
Author Topic: ShiftPWM SPI Clock signal noise  (Read 383 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hello,
I am using arduino mega 1280 with shiftpwm library to run couple of shiftregisters with uln2003 that drives high power leds. I had some noise problems with >2 registers connected. I suspected the CLK signal so I disconnected all the registers and plugged usbee logic analyzer straight into the clock pin. The latch and data signal looks good (probably because it's lower frequency), but the clock signal has lots of saw spikes here is image of it http://masz.in/spi_shift/clock%20signal.jpg
The clock is running @ 4Mhz. I guess that the longer cable the worst signal this is probably why the more registers i add the bigger noise i have. Do you have any idea how to resolve this issue? Schmitt Trigger? Low Pass/High Pass filtering? Help!
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
On this picture Digital 0 is the clock signal and Bus is the data signal? What's the sample rate of your USBee? More than 10MS/s? Doesn't look that bad to me. From the speed I'd guess you're using the hardware SPI, aren't you?
Can you define "noise problems"? How do these show up?
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Do you have decoupling caps on the shift register Vcc pins (0.1uF cap from +5 to Gnd near the Vcc  pin)?
You could also look at terminating the clock line to clean it up.
http://www.fairchildsemi.com/an/AN/AN-393.pdf
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
Newbie
Arduino rocks
View Profile
Both signals are clock, one is "analog" reading the other is digital. Usbee runs at 16mbps.
http://m.youtube.com/#/watch?v=SR9LhPwdWqg this is how it looks like. There should be one triangle lit up at one time.
And yes its hardware SPI that ShiftPWM uses on Mega its 52,51 and 8 for latch
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Yes I do have decoupling, on power line 100nF, 1uF, 10uF. Also on the 595 chips between vcc and gnd 100nF just on top of the register.
By terminating you mean for ex. from last clock 10k resistor to gnd?
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
16Ms/s is not enough to get a realistic picture of a 4MHz clock signal.
The lower part of the picture is very strange because the digital interpretation and the analog signal curve doesn't look synchronized. Is this offset normal for the USBee or are these different signals?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
"By terminating you mean for ex. from last clock 10k resistor to gnd?"
Yes, or look at some of the examples in the article
Your image capture might also look worse than it really is, can be impacted by things like where your probe grounds were connected.
Logged
Pages: [1]   Go Up
Print
Jump to:
