Topic: which board do I have?? (Read 896 times) previous topic - next topic
syphex
What I purchased was advertised as an arduino duemilanove, it says arduino "UNO" on it.
Trying to find it on the "getting started" page, I assume its the Arduino "Due" for "Duemilanove" but it looks nothing like the picture describing the serial ports as the whole board is too big.
So I think.. maybe its the mini? I click on mini and see its a smaller long board compared to my own. After scrolling down I see one like mine is a "Regular" board, described as an Arduino NG which is exactly like mine except mine still has the AT mega.
So where exactly can I find the getting started for MY "regular" arduino board????
strykeroz
Arduino Duemilanove was the model prior to the Uno and they're still commonly made & sold.  Check here for more specs.  It is very close to the Uno in spec, but has different hardware for the USB interface.
Cheers ! Geoff
"There is no problem so bad you can't make it worse" - retired astronaut Chris Hadfield
baselsw
show us a picture of the board.. Which IC is the board using, Atmega328p, atmega168p.. The FTDI/USB part, which chip is it using, atmega8u2/16u2 or FTDI 232RL?
fungus
#3
Mar 05, 2013, 10:41 pm Last Edit: Mar 05, 2013, 10:44 pm by fungus Reason: 1
"Duemilanove" means "2009" in Italian. The Duemilanove was made in 2009 and is the precursor to the Uno.
http://arduino.cc/en/Main/ArduinoBoardDuemilanove
An Arduino Uno is newer/better than a Duemilanove.
"Arduino Uno" means "Arduino 1"
"Arduino Due" means "Arduino 2"
The Arduino 2 is a 32 bit ARM based Arduino.
retrolefty
You can try and match it up with those products shown here:
http://arduino.cc/en/Main/Boards
Lefty
James C4S
Due is a brand new board released in the past year.  It has absolutely nothing in common with the Duemilanove.
As others have stated, you should probably post a picture of it.  Or at least identify the USB to Serial chip it is using.
