Topic: Telling a function to use a motor (Read 739 times) previous topic - next topic
IAM_Carbon_Based
Mar 06, 2013, 12:44 am Last Edit: Mar 06, 2013, 12:47 am by IAM_Carbon_Based Reason: 1
I have written a function to control the direction and speed of a stepper motor (fwd_rev) and would like to be able to tell this function what motor to use, as I'm going to add a second and third.
I do not want to write a new function for each motor and don't think i have to but I can't figure out have to do it.
Here's my code:
* XY_CNC.cpp
#include <arduino.h>
#include <Stepper/Stepper.h>
/********************** Define Global Variables Here *************************/
#define btn1 6 // Button 1 Pin
#define btn2 7 // Button 2 Pin
#define adj1 3 // Adjustment 1 input Pin
#define en 8 // Enable pin for SN754410 IC's
#define clk_pin 10 // Pin for 595
#define latch_pin 11 // Pin for 595
#define data_pin 12 // Pin for 595
Stepper s1(96, 2,3); // Y Stepper
Stepper s2(48, 4,5); // X Stepper
word s1_RPM;
word s2_RPM;
word btn1v = 0; // Value for Button 1
word btn2v = 0; // Value for Button 2
/********************** Custom Functions Here ***********************/
void fwd_rev(int b1, int b2, int RPM, int numstep){
/* This function controls the forward and reverse of the stepper motor.
Allows you to define the forward and reverse buttons to use.
As well as the minimum # of steps per function call the motor will operate at,
"b1" and "b2" are the values of the buttons controlling the motor.
"RPM" is self explanatory.
"numstep " is the minimum number of steps the motor should make as required by the stepper library.  */
s1.setSpeed(RPM);
if (b1 == 0 && b2 == 1){
digitalWrite(en, HIGH);
s1.step(numstep);
if (b1 == 1 && b2 == 0){
s1.step(-numstep);
if(b1 == 1 && b2 == 1){
digitalWrite(en, LOW);
int adj_dial(int pin, int min, int max){
/* This function will read from an adjustment pin and return the value read.
the value is mapped between min and max values */
int rval; // Return Value
int adj_val = analogRead(pin);
rval = map(adj_val, 0, 1023, min, max);
return rval;
void display(int disp){
/* This function will take a 3 digit INT and display the number on the 7 segment display */
byte num[10] = {254,48,109,121,51,91,95,112,127,115};  // Display bits 0-9
word ones = disp % 10;
word tens = (disp - ones) % 100;
word hund = (disp - tens - ones) % 1000;
byte dc1 = ones;
byte dc2 = tens / 10;
byte dc3 = hund / 100;
digitalWrite(latch_pin, LOW);
shiftOut(data_pin, clk_pin, LSBFIRST, num[dc1]);
shiftOut(data_pin, clk_pin, LSBFIRST, num[dc2]);
shiftOut(data_pin, clk_pin, LSBFIRST, num[dc3]);
digitalWrite(latch_pin, HIGH);
/****************************** Setup *********************************/
pinMode(btn1, INPUT_PULLUP);
pinMode(btn2, INPUT_PULLUP);
pinMode(en, OUTPUT);
pinMode(clk_pin, OUTPUT);
pinMode(latch_pin, OUTPUT);
pinMode(data_pin, OUTPUT);
// Serial.begin(9600);
/******************************** Main Loop ********************************/
btn1v = digitalRead(btn1);
btn2v = digitalRead(btn2);
s1_RPM = adj_dial(adj1, 50, 300);
display(s1_RPM);
fwd_rev(btn1v, btn2v, s1_RPM, 1);  // --> I want to do this:  fwd_rev(btn1, btn2, s1, RPM, 1);
marco_c
Learn to use pointers, then you can pass a pointer to the motor object to the function. Lots of stiuff out there on this, including tutorials, but the basics are:
The address of an object or variable is given by &varname, so calling a function with
function_name(&varname);
passes a pointer to the variable.
The function declaration needs to be
function_name(type *varname)
that makes varname a pointer to a variable of type
Then to reference the methods of the object you use ->
varname->method();
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
IAM_Carbon_Based
Pointers are so far the most confusing thing I've encountered so far. BUT I've got it working, Thank you.
marco_c
Think of it this way.
Your house is somewhere in a street that is part of a city. To find your house you give out the address. This is effectively a pointer to your house.
A variable is at a memory address that is part of bigger memory space. To find the variable you can use the memory address of that variable. That is all that a pointer is.
You are effectively manipulating the memory address of the variable rather than the variable itself. That is a very powerful thing to do, as it allows all sorts of cool techniques to happen when programming.
Anyway, glad to see hear it works.
JimboZA
I was at a client many years back, where a new-ish employee had been doing quite well getting her mind round programming. She was, rightly, quite pleased with her progress.
So then one of the older hands said to one of the other guys, "Ok, shall we tell her about pointers now?" with an evil grin; unsaid was ".... she's getting a bit big for her boots."
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
