Topic: still run functions while in delay (Read 3506 times) previous topic - next topic
hilukasz
seem to have a problem that while a function is running which has some delays and digitally increments the brightness of an LED it seems I cannot run anything in between. is there a way to check for example, a button press, while something is in a delay or being incremented?
for(i = 0, i < 820480075, i++){ Design(); Code(); delay(1000); } // hellowoo.com
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
Xnor
http://www.gammon.com.au/blink
Perfect!
Thanks, that's exactly what I was looking for.
hilukasz
hilukasz
#4
Mar 06, 2013, 06:21 am Last Edit: Mar 06, 2013, 06:23 am by hilukasz Reason: 1
ok since I am using an Unsigned Integer in this example which can hold a decent count (4,294,967,295) is that a concern of the program crashing? (this thing might be on for several days) Is there a standard practice of reseting the count when it gets to a certain value? that seems like the likely solution...
retrolefty
ok since I am using an Unsigned Integer and that can hold a decent count (4,294,967,295) is that a concern of the program crashing? Is there a standard practice of reseting the count when it gets to a certain value? that seems like the likely solution...
No concerns. As Nick told in the tutorial as long as you arrange your elapsed time testing calculations as a subtraction there is no hazards to deal with.
Lefty
nickgammon
No, it won't. 65535.
Arrch
ints are 16-bit
lonbs are 32-bit.
retrolefty
ints are 16-bit
lonbs are 32-bit.
LOL. lonbs, Is that one of those fancy new C++ data types?
hilukasz
someone should fix the arduino documentation then :P http://arduino.cc/en/Reference/UnsignedLong
nickgammon
unsigned int is not the same thing as unsigned long
nickgammon
See this: http://arduino.cc/en/Reference/UnsignedInt
You said:
Quote
... since I am using an Unsigned Integer in this example ...
hilukasz
#12
Mar 07, 2013, 04:59 am Last Edit: Mar 07, 2013, 05:01 am by hilukasz Reason: 1
You said:
Quote
ooo, you're right. had that pulled up 2am last night when I was reading it. doh. guess I was referring to the tutorial though, it uses a UL or unsigned long. But I see better now how it is used.
