Canberra Australia
Offline
Sr. Member
Enthusiastic Newbie
« on: March 06, 2013, 02:38:35 am » |
I burnt the bootloader to a 328P chip by following Nick’s tutorial at http://www.gammon.com.au/forum/?id=11637I assume that I was successful, because if I placed the newly bootloaded chip into a Uno and uploaded a blink sketch it worked. I then purchased this FTDI cable from http://www.ebay.com.au/itm/321058835137?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#The FTDI connections are Red-5v Black-GND White-Rx Green-TX Yellow-RTX Blue-CTS So I connected TX to Pin 2 (RxD) Rx to Pin 3 (TxD ) RTX to reset via 0.1 uF cap And power and ground with the chip on a breadboard wired up as per the circuit on Nick’s tutorial. When I tried to upload a sketch (ASCII table or Blink) I get that all too familiar error avrdude: stk500_getsync(): not in sync: resp=0x00. I have the com port set to the one that Windows assigned it when I first connected the FTDI cable and the board set to Uno. Presumably Windows also assigned some generic drivers. There is no LED activity on the cable when attempting to upload the sketch. Can anyone please suggest anything that I might try. Thank you.
Logged
Valencia, Spain
Offline
Edison Member
« Reply #1 on: March 06, 2013, 02:43:15 am » |
Swap the RX and TX?
nb. Put some 220/330ohm resistors in until you're 100% sure.
Logged
Canberra Australia
Offline
Sr. Member
Enthusiastic Newbie
« Reply #2 on: March 06, 2013, 02:52:15 am » |
Yes I already tried that when it didn't initially work thanks Fungus, but still "no go". Thanks anyway
Logged
Valencia, Spain
Offline
Edison Member
« Reply #3 on: March 06, 2013, 03:26:40 am » |
When you say "There is no LED activity on the cable when attempting to upload the sketch" do you mean the cable has built-in LEDs?
If so, it's probably the Windows driver.
Logged
Canberra Australia
Offline
Sr. Member
Enthusiastic Newbie
« Reply #4 on: March 06, 2013, 03:45:15 am » |
Yes the cable has built in Tx and Rx LED's. I might contact the Ebay vendor and see if he can point me to some drivers. Thanks for your help Fungus.
Logged
Global Moderator
Boston area, metrowest
Offline
Brattain Member
Available for Design & Build services
« Reply #5 on: March 06, 2013, 09:22:26 am » |
Pedro, its an FT232 based board? (can't open ebay from here). Drivers are at ftdichip.com Is it RTX, or RTS? Try leaving that off an press & hold Reset on your board, release it when the IDE shows "Compiled xxx of 32xxx bytes" That will at least prove out the Rx/Tx connections.
Logged
Valencia, Spain
Offline
Edison Member
« Reply #6 on: March 06, 2013, 09:44:40 am » |
I had a similar problem with Windows 7 and an FTDI adapter board. Windows said it installed the drivers but it was lying. If the driver isn't signed you have to install it manually with the device manager->"have disk..." thingy.
Logged
the land of sun+snow
Offline
Edison Member
« Reply #7 on: March 06, 2013, 01:51:12 pm » |
Also, if the pin labelled "RTX" really is RTS [ie, 3rd party documentation is always such a treat], then you have to go to the Control Panel and enable "System > Hardware > Device Manager > Ports > USB Serial Port > Port Settings > Advanced > Set RTS On Close".
Also, with some of those devices, the signal levels are 3.3V and some are 5V, and I would measure them rather than make any assumptions. Also, I always use series-Rs with those sort of cables too.
Logged
Canberra Australia
Offline
Sr. Member
Enthusiastic Newbie
« Reply #8 on: March 06, 2013, 02:15:56 pm » |
Crossroads / Fungus , from the description on Ebay – FTDI based USB to TTL Serial Cable are designed using the the standard FT232RL chipset red-5v , black-GND , white-Rx , green-TX , yellow-RTX , blue-CTS I did uninstal the drivers Windows selected and then installed and unsuccessfully tried some drivers that I downloaded from ftdichip.com , but when I checked driver details in device manager they were the same drivers. I have the 328 set up on a breadboard with the FTDI cable RTX wire going to 328 pin 1 via a 0.1 uF cap with a 10 K resistor to + 5v as per Nick Gammon's suggestion at http://www.gammon.com.au/forum/?id=11637 So do you suggest that I fit a reset switch with resistor and leave the yellow RTX line from the FTDI cable disconnected, and then “press & hold Reset on your board, release it when the IDE shows "Compiled xxx of 32xxx bytes" or am I misunderstanding ? Oric dan thanks I will also have a look at that possibility after work. Yes Ebay items are cheap but when it comes to the information that some vendors supply, the saying “cheap and nasty” comes to mind
Logged
Global Moderator
Offline
Brattain Member
« Reply #9 on: March 06, 2013, 02:26:05 pm » |
"fit a reset switch with resistor and leave the yellow RTX line from the FTDI cable disconnected, and then “press & hold Reset on your board, release it when the IDE shows "Compiled xxx of 32xxx bytes" "
Yes, try that. Driver should assert RTS or DTR to create a reset. Don't know what RTX is. Might take a couple of tries to find the right reset release time for the bootloader to start and catch the download message from the PC.
Logged
Left Coast, CA (USA)
Online
Brattain Member
Measurement changes behavior
« Reply #10 on: March 06, 2013, 02:31:20 pm » |
author=Pedro147 link=topic=152505.msg1145526#msg1145526 date=1362597356] Crossroads / Fungus , from the description on Ebay – FTDI based USB to TTL Serial Cable are designed using the the standard FT232RL chipset red-5v , black-GND , white-Rx , green-TX , yellow-RTX , blue-CTS I did uninstal the drivers Windows selected and then installed and unsuccessfully tried some drivers that I downloaded from ftdichip.com , but when I checked driver details in device manager they were the same drivers. I have the 328 set up on a breadboard with the FTDI cable RTX wire going to 328 pin 1 via a 0.1 uF cap with a 10 K resistor to + 5v as per Nick Gammon's suggestion at http://www.gammon.com.au/forum/?id=11637 So do you suggest that I fit a reset switch with resistor and leave the yellow RTX line from the FTDI cable disconnected, and then “press & hold Reset on your board, release it when the IDE shows "Compiled xxx of 32xxx bytes" or am I misunderstanding ? Oric dan thanks I will also have a look at that possibility after work. Yes Ebay items are cheap but when it comes to the information that some vendors supply, the saying “cheap and nasty” comes to mind  The problem is that in the RS-232C standards that define the control signal names and their purpose, the name RTX is not a defined signal name, so it's not clear what it is, an input signal for the cable? An output signal from the cable? If it's really the standard named RTS (Request To Send) signal then it can be used as the auto-reset trigger signal the arudino IDE uses to start the sketch upload process, by wiring to a series .1ufd cap wired to the reset pin. The arduino IDE/AVRDUDE use both the RTS and DTR signals for that purpose so either can be used to generate the reset pulse to the board. Lefty
« Last Edit: March 06, 2013, 02:32:53 pm by CrossRoads »
Logged
Offline
Edison Member
« Reply #11 on: March 06, 2013, 02:50:27 pm » |
I just tried something that may help see what's what. I have both FTDI cable [uses RTS reset] and FTDI Friend [uses DTR reset]. I put an Led [w/series-R, of course] on the pins on the "cable" side of the 0.1 uF blocking cap, so can watch the reset signals directly from the cable. Just looked at it, did not use a scope to watch for short pulses.
FTDI cable - RTS: held low, blinks high briefly a couple of times at the beginning of upload, then high pulse again at the end of upload, then goes low. FTDI Friend - DTR: held high, goes low during entire upload, then high again.
Logged
Canberra Australia
Offline
Sr. Member
Enthusiastic Newbie
« Reply #12 on: March 06, 2013, 03:35:57 pm » |
Thanks for your help and suggestions gents. I will have to spend a little time going through them all. I'll let you know how I go.
Logged
Canberra Australia
Offline
Sr. Member
Enthusiastic Newbie
« Reply #13 on: March 07, 2013, 06:36:44 am » |
I tried all your suggestions, Firstly - Crossroads – I Wired up reset switch and left RTX line disconnected, held then released switch just as / just after code compiled but to no avail. Fungus – I uninstalled the drivers Windows assigned then manually installed drivers that I downloaded from ftdi.com but upon closer inspection found that they were exactly the same drivers. Lefty - to be honest I really don’t know what I’ve got here.. maybe a pig in a poke  Oric_dan - firstly I checked the voltage between the Gnd and power leads of the FTDI cable and it is 5.46 volts. I changed the port settings to set RTS on close but still no successful upload. I then connected a series resistor and LED to “cable side of the 0.1 uF blocking cap” as per attached circuit diagram. The LED doesn’t light while the code is compiling then as it starts to try and upload, it briefly flashes on / off then comes back on while the code tries to upload. It then goes out when the avrdude: stk500_getsync(): not in sync: resp=0x00 error displays. From my rudimentary electronics understanding does this mean that seeing as the LED on the RTX line has it’s anode to + 5V that the RTX line is low when the LED is illuminated ? Does any of this information help to ascertain what is happening here or could someone just point me to an online store, with reasonable postage rates to Australia, where I can purchase a FTDI cable that works out of the box, so to speak. Thanks again to you all, for your help, Pedro.
Logged
Wahiawa, Hawaii
Offline
Sr. Member
« Reply #14 on: March 07, 2013, 06:50:27 am » |
Where is your crystal? I don't see one in your schematic. It won't work unless you set your fuses for internal clocking. Otherwise you will need to add an external crystal(w/caps) or a resonator.
Logged
