Author Topic: q: magnetic fields and conductor isolation  (Read 348 times)
Waterloo, Canada
Engineer
I've gotten to the point in my project where I'm cutting holes in my project box for cabling.  I'm realizing I have some questions about noise, insulation, isolation, magnetic field intensity.
Specifically, what measures (if any) do I need to separate/insulate the high current carrying conductors from the analog signal carrying conductors?
My project includes...
  6 x 1amp @ 12V solenoids switched by MOSFETs
  2 x 2amp @ 12V heater circuits
  multiple 5 V signals passed in/out between Arduino and other digital logic devices and sensors (analog).
I've calculated the magnetic field intensity for some of the higher current conductors (ground sink for the solenoids in particular) at a distance of 1mm (est. of AWG 20 w insulation):
  B = mu_not / (2*pi) * I/d = 1.2E-3 Tesla
  mu_not = magnetic field constant = 1.26E-6
  I = 6A
  d = 0.001m
  *ref http://www.fizika.org/skripte/of-prakt/4_3_05.pdf
This is unfamiliar territory to me.  Is this a correct calculation?  Is this magnitude of magnetic field small/tiny/medium/other?  I need to consider what voltage levels could be coupled onto adjacent conductors from this magnetic field expanding and collapsing while the Solenoids are switched.
My thoughts:  I found reference that the earth's magnetic field is on the order of 10^-5 Tesla.  This magnetic field is 100 X larger @ 1mm from the conductor.  To me this sounds negligible.
Your thoughts: <here>
-MDH
Dallas
Online Online
Shannon Member
Have you considered trying to measure the induced current?  You do have an Arduino with an A/D converter.  Unfortunately, if you guess wrong about scaling the voltage to be measured you could damage the Arduino.
Waterloo, Canada
Engineer
The at1280 DAC isn't fast enough for that.  Field collapse will be extremely quick.  What I probably need is a 20MHz scope (which I don't have).
I do appreciate the suggestion though.
-MDH
Left Coast, CA (USA)
Measurement changes behavior
Is this a solution looking for a problem.  smiley-wink
Lefty
SF Bay Area (USA)
Online Online
Strongly opinionated, but not official!
I would worry less about magnetic fields of the conductors causing problems, and more about "noise" induced on the common wires.  Almost ALL of the circuit protection schemes I've seen have been about radiated RF-frequency stuff and conducted noise in power supply traces, rather than currents induced by magnetic fields...
Which doesn't mean that  it's not a good idea to keep your high-current wires and traces as far as possible from high-impedence digital or analog circuits...
Waterloo, Canada
Engineer
Power-trace noise is another concern, but for those issues I have measures in place.
Maybe the reason I can't easily find any info on this is because it is not a typical concern in elec design...
Manchester (England England)
Solder is electric glue
I am not sure why you are worried about this. The only problem with magnetic fields is that they induce noise voltages in adjacent conductors. This can be a problem in designs with chokes or transformers but is seldom a problem with single conductors due to the small fields involved. If you do want to shield against a magnetic field then you can use mu-metal.
http://en.wikipedia.org/wiki/Mu-metal
This is a metal alloy designed to do this and you can get it in laminated foil sheets that can be cut with scissors.
« Last Edit: December 14, 2009, 04:15:03 am by Grumpy_Mike » Logged
Waterloo, Canada
Engineer
Oh good, Grumpy_Mike is here!  I was hoping you'd spot this thread.
I'm not sure either.  I was hoping it would not be an issue.  I'll take my cue from "seldom".
Thanks for the link.
In general I don't do weekends.  smiley-wink
