Topic: Please help me! i dont know what im doing wrong! (Read 1 time) previous topic - next topic
sussegado
Mar 06, 2013, 02:20 pm Last Edit: Mar 06, 2013, 02:23 pm by sussegado Reason: 1
Hello everyone, im new on this forum.
I buy an arduino board and I'm trying to build a robot tank to my son
but I doing something wrong on program code.
When I press the button (switch_Pin),
the tank move forward and when something in front is near (less than 30cm)
stop, DET_LED light on, back a little and move IR sensor to right, read rdistance
next rotate left and read ldistance.
And the next step is not working, because I need to compare rdistance and ldistance
but it not working, tank always move the same direction.
The code dont compare rdistance>ldistance and go right or ldistance>rdistance go left.
Please I need some advice! Thanks
ps: sorry about my english! im from japan!
thats the code!
#define LEFT_M 12  //Direction Motor A
#define LEFT_S 3   //Speed Motor A
#define RIGHT_M 13 //Direction Motor B d
#define RIGHT_S 11 //Speed Motor B
#define FORWARD HIGH
#define REVERSE LOW
#define DET_LED 9 //Led de Alerta
#define LED_PIN 10 //Led de Operacao
#define FRONT1_LED 4 //Led de Alerta
#define FRONT2_LED 5 //Led de Operacao
#define switchPin 2 //Botao de Start
#include <Servo.h> // biblioteca do servomotor
Servo servoMain;
#define FRONT_IR 0
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
long randNumber;
void start_wait() //wait for start
  // set the brightness of pin 5:
  analogWrite(LED_PIN, brightness);
  // change the brightness for next time through the loop:
  brightness = brightness + fadeAmount;
  // reverse the direction of the fading at the ends of the fade:
  if (brightness == 0 || brightness == 255) {
    fadeAmount = -fadeAmount ;
    delay(25);
void full_stop()  //procedure FULL STOP
  analogWrite(RIGHT_S,LOW);
  analogWrite(LEFT_S,LOW);
void forward(int mspeed, int mtime)  //procedure to RUN FORWARD
  digitalWrite(LEFT_M,FORWARD);
  analogWrite(LEFT_S,mspeed);
  digitalWrite(RIGHT_M,FORWARD);
  analogWrite(RIGHT_S,mspeed);
  if(mtime > 0)
    delay(mtime);
    analogWrite(LEFT_S,0);
    analogWrite(RIGHT_S,0);
void reverse(int mspeed, int mtime) // procedure to RUN REVERSE
  digitalWrite(LEFT_M,REVERSE);
  digitalWrite(RIGHT_M,REVERSE);
  if(mtime > 0)
    delay(mtime);
void left(int mspeed, int mtime)  //procedure to go left
  if(mtime > 0);
    delay(mtime);
void right(int mspeed, int mtime)  //procedure to go right
  if(mtime > 0);
    delay(mtime);
int front_sens()
  int tmp,distance_r,distance_l,distance;
  tmp = analogRead(FRONT_IR);
  if(tmp < 4) tmp = 4;
  distance = (6787 / (tmp / 3)) -4;
  return(distance);
int rfront_sens()
  int tmp,rdistance,ldistance,distance;
  rdistance = (6787 / (tmp / 3)) -4;
  return(rdistance);
int lfront_sens()
  ldistance = (6787 / (tmp / 3)) -4;
  return(ldistance);
int val;             //variavel do botao
int buttonState = 0; //estado do botao inicial
  // Motores
  pinMode (LEFT_M,OUTPUT);
  pinMode (LEFT_S,OUTPUT);
  pinMode (RIGHT_M,OUTPUT);
  pinMode (RIGHT_S,OUTPUT);
  //botao de start
  pinMode (switchPin,INPUT);
  //LEDs
  pinMode (LED_PIN,OUTPUT);
  pinMode (DET_LED,OUTPUT);
  //Servomotor
  servoMain.attach(8);
  int left_val;
  int right_val;
  int i;
  val = digitalRead(switchPin);
  full_stop();
  digitalWrite(LED_PIN,HIGH);
  if(val != buttonState)
    while (val == LOW)
      if(val == HIGH)
        Serial.println("button is not pressed");
        break;
        Serial.println("button is pressed");
        //forward(255,0);
        while(front_sens() > 30)
          forward(200,0);
        if(front_sens() < 30); //something near
          digitalWrite(DET_LED,HIGH);
          Serial.println("Warning Warning");
          full_stop(); // parada total
          reverse(200,500);
          full_stop();
          left_val=0;
          right_val=0;
          servoMain.write(5);
          right_val = rdistance;
          Serial.print(rdistance,DEC);
          Serial.print(" cm\n");
          servoMain.write(90);
          servoMain.write(175);
          left_val = ldistance;
          Serial.print(ldistance,DEC);
          if(left_val=right_val)
            while(1)
              left(200,900);
              break;
            if(right_val>left_val)
            while(1)
              left(200,900);
              break;
            if(right_val<left_val)
              while(1)
                right(200,900);
                if(front_sens()>25)
                  break;
          digitalWrite(DET_LED,LOW);
  buttonState = val;
AWOL
#1
Mar 06, 2013, 02:46 pm Last Edit: Mar 06, 2013, 02:51 pm by AWOL Reason: 1
if(mtime > 0);
Lose the semicolon (";")
int front_sens()
 return(distance);
There's no need for "distance_r" or "distance_l"
int front_sens()
 int tmp = max (4, analogRead(FRONT_IR));
 return  (6787 / (tmp / 3)) -4;
Better still:
int range(byte rangePin)
  int tmp = max (4, analogRead(rangePin));
sussegado
Thank you for reply AWOL
I delete the ";", but I think my problem is inside the void loop()
because I create a rdistance and ldistance but the tank still doing the last "else"
right(200,900);
I read a lot of help about "if" "else if" and "else" but i cant make the tank to go left or right!  :smiley-red:
If someone know what im doing wrong or have a advice to use "if", plz tell me! thank
AWOL
You have a few variables with the same name in the main loop, so what you think you're using may not be what the compiler is using - it looks like you've just cut-and-pasted code without regard for the excess variables.
I'd look to simplify, and take out the inlined ranging in "loop()" and use the function I showed instead.
AWOL
#5
Mar 07, 2013, 02:52 pm Last Edit: Mar 07, 2013, 03:29 pm by AWOL Reason: 1
Post your code, post your results/observations.
That's not going to go well.
Nor that.
Also, this
while(1)
              left(200,900);
              break;
which is repeated with slight variations a few times, is the same as
left(200,900);
, which is shorter and easier to read.
