Topic: Slow data transmission from Arduino+Bluesmirf to P (Read 554 times) previous topic - next topic
protozoo
Hi there,
I am trying to use a Bluesmirf bluetooth component attached to an Arduino duemillanove to send sensor values to my processing sketch. I finally managed to read values on the processing side, but I notice the data exchange is REALLY SLOW. I added some simple code to measure how much time it takes between readings. Using the USB cable I get 30ms average, but using the same code with the Smirf it takes 10x ( 300ms), making my project unusable.
Is this normal or I'm doing something wrong? Here's the Arduino code:
Code: [Select]
// Arduino code
int counter = 0;
 while( Serial.available() <= 0 )
   Serial.print('\r', BYTE );
   delay(300);
 while( Serial.available() > 0 )
   int inByte = Serial.read();
    counter++;
   if(counter >= 200 )
     counter = 0;
   Serial.print( 0, DEC );
   Serial.print( ',' );
   Serial.print( 1, DEC );
   Serial.print( 2, DEC );
   Serial.print( 3, DEC );
   Serial.println( counter, DEC );
And the Processing one:
Code: [Select]
// Processing code
import cc.arduino.*;
import processing.serial.*;
Serial myPort;
boolean madeContact = false;
int lineFeed = 10;
int lastValue = 0;
int lastPing = millis();
 size(400, 200);
 println( Serial.list() );
 myPort = new Serial(this, Serial.list()[0], 9600 );
 myPort.bufferUntil( lineFeed );
void draw() {
 background(0);
 if( madeContact == false )
   println( "----------------" );
   myPort.write('\r');
 stroke(255);
 line( 10, lastValue, 50, lastValue );
void serialEvent(Serial p )
 if( madeContact == false)
   myPort.clear();
   madeContact = true;
   myPort.write( '\r' );
 String myString = myPort.readStringUntil( lineFeed );
 if( myString != null )
   myString = trim( myString );
   int sensors[] = int( split( myString, ',') );
   if( sensors.length == 5 )
     for( int sensorNum=0; sensorNum<sensors.length; sensorNum++ )
       print( "Sensor " + sensorNum + ": " + sensors[sensorNum] + "\t");
     lastValue = sensors[4];
     int time = millis() - lastPing;
     print( "  ::::  " );
     print( time );
     println();
Thanks in advance!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
