Topic: Circuit Help (Read 1 time) previous topic - next topic
shutterflypro
Can someone give me a little guidance here.  I am wanting to take a varying incoming voltage and output a steady 12 volts.
I am assuming I would need a voltage regulator of some sort but am coming up short with google.
Thanks in advance
johnwasser
If the incoming voltage is below 12 you want a "boost regulator".  If it is always well above 12 you could use a "linear regulator" or more efficient "switch-mode regulator".  If the input is sometimes above and sometimes below 12V I think you need a "Boost/Buck regulator".
