Author Topic: Relay shield  (Read 724 times)
Athens
has anyone used this relay shield by seeed (http://www.seeedstudio.com/depot/relay-shield-v20-p-1376.html?cPath=132_134)? Is it good, or does anyone have any other suggestion? Plus, haven't done anything with relays yet, but want to give it a try, so can you use it to fade lights in and out, or is it only on/off?
thanks
Massachusetts, USA
Relays are too slow to dim lights.  Use a transistor or MOSFET.
Athens
Is there any MOSFET shield you would recomend? Some available code maybe?
It doesn't look as popular as the relay shields (after a quick search)...
Dubuque, Iowa, USA
What type of light (voltage / amps / AC or DC)?
Athens
to be honest I don't really know. it's an idea for a noise music performance. i want the sound amplitude to control the brightness of a couple of lights (that will be done with a computer sending data to arduino). some quite strong light would be good, but since i've never dealt with something like that before, i don't know what i should be looking for..
Left Coast, CA (USA)
Measurement changes behavior
Ten channels of mosfet outputs:
http://www.ebay.com/itm/Arduino-FET-shield-/370593835709?pt=LH_DefaultDomain_0&hash=item56491d2abd
Lefty
ciao
hi to all,
i'm newbei with arduino...
i have bought this relay shield
http://www.robot-italy.com/it/relay-shield.html
 to pilot a 40W light, but i have bad result
the relay on the board is exploded and also arduino uno on the bottom is injuried.
for the next try can you tell another relay board that can support this load.
i have thinked that 3A 120V AC was good for 40W
3*120=360W
but now i know that this is wrong...
Can somebody help me, please?????
i have seen v2.0 of that shield with 10A 250V~
http://www.robot-italy.com/it/relay-shield-v2-0.html
is ok??????
Dubuque, Iowa, USA
The board you exploded should have worked fine for a 40W bulb driven with 120V AC. Either you made a connection mistake or you just got a faulty board.
Johannesburg UTC+2
Or, you put 220 Euro-Volts thru it.....
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
mmm...yes i'm living in italy
220 V is the Volts here
so what can i do now????
