Topic: How to test power supply under a load? (Read 3317 times) previous topic - next topic
bratan
I have a bunch of adjustable DC power supplies which I need to adjust to 5 VDC output, but I suspect that when I just test it with multimeter it won't show correct voltage. Would would be a simple way to test it under load? Put some kind of resistor between power supply output and multimeter?
Xronos Clock - A talking arduino based alarm clock is now available. Check out xronosclock.com for pictures, source code, schematics, etc.
fungus
If it's regulated supply (aka. switching) then it shouldn't make any difference.
PS: You could always try one and see ... that's how we learn! :)
retrolefty
Measuring the power supply under a 'dummy load' is a good idea. It doesn't have to draw the maximum current rating of the supply to still be a valid test. What type of load is best/easiest to use depends on the maximum current rating of the supply. Be sure if you do use a fixed resistor that it's wattage rating is well above the wattage it will consume.
Lefty
E40racer
I have a bunch of 10W 5 and 10 ohm cement resistors for this purpose.
www.bajdi.com
JimboZA
That sounds like you're thinking in series?- I think parallel is the correct way, ie the load is across the power supply and you in turn measure the voltage across the connections. I'm no expert, but that makes more sense to me....
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
retrolefty
Yes one measures voltage in parallel with the power supply output terminals and one measures current in series with the load.
Lefty
JimboZA
I'm bored so I drew a pic of that  8)
bratan
Thank you, that's actually what I was looking for! :)
Yes it's switching DC to DC based on LM2596. I'm getting different output voltage depending on the input voltage (i.e. at 5 V in I'm getting 4.8V, and at 12 V I could be getting 5.5V). I read it it could be because I'm measuring without a load, thus my original question :)
Not sure what you mean by "try one and see".
SirNickity
That's common with switching supplies.  They often have good regulation under various loads, but under no-load conditions, they'll be a bit unpredictable.  The output filter (converts pulses into smooth DC voltage) needs a resistive element to complete the filter.  It shouldn't take much to start coming together.
jackrae
I often use simple car lamps as test loads since you can then see the actual load in operation.
bratan
Thanks! I measured it under load (actually wired to finished project), and it's strange but I'm not getting above 4.5V output when I'm using 5V input supply. No matter how far I adjusted it. Is it expected?  It's rated for 4-35V, but maybe I'm hoping for too much here :) It has no problem giving 5V out with 6VDC and higher supply...
fungus
So it's a voltage booster...?
If you want good answers you could start out by saying what you're doing/using. So far everybody has assumed a switch-mode power supply with an adjustment screw.
bratan
For some reason I thought it was a booster, I guess not..
Here it is:
http://www.ebay.com/itm/1pcs-DC-DC-Buck-Converter-Step-Down-Module-LM2596-Power-Supply-Output-1-23V-30V-/370772814758
I use it to power my custom ATMega644P board that also has RTC, WaveShield and 32x16 LED matrix display...
fungus
"Buck" means it can only reduce the voltage.
Problem solved...
retrolefty
Here it is:
Your hint should have been the "Step Down" in the product title.
Lefty
