Loading...
Pages: [1]   Go Down
Author Topic: Nano with feedback control add-on to control two motors  (Read 169 times)
Offline Offline
Newbie
View Profile
Hi
I am new to the Arduino community.
I am working on an engineering school design project to point a camera at moving a target.
The camera will be able to move on the x-axis (rotate left and right) and on the y-axis (rotate up and down).
I found this "2MOTOR w/ Feedback Control add-on for Arduino Nano" http://www.gravitech.us/2mwfecoadfor.html
can anyone tell me if this add-on paired with the Arduino nano would be a suitable choice for this project?
I want a microcontroller that can operate two motors for the camera movement, and process the input from a RF sensor to locate to the camera target.
Can anyone give me insight on how to do this, or tell me if the nano with the add-on above is a good choice?
Logged
Offline Offline
Edison Member
View Profile
An Arduino can control a motor with a motor shield.
For example if you want to spin your camera around with 1000 rpm.
Or do you want a motor with a gear ?
You will perhaps also need sensors to detect the rotation and tilting angle.
An Arduino can control a servo motor without motor shield.
Just connect a pin of the Arduino to the signal wire of the servo.
You need a good seperate power supply for the servos.
The Servo library is easy to use.
http://arduino.cc/en/Reference/Servo
Controlling the speed of the servo is not very easy.
How do you track the point the camera the looking at ?
What kind of motors do you want to use ?
Logged
Pages: [1]   Go Up
Print
Jump to:
