Topic: RLFIN Command always returns 0 value to ardunio (Read 2483 times) previous topic - next topic
scholarium
char query()
  Serial.println("#S|QUERY|[1]#");   //RLFIN Gobetwino
   if (Serial.available())
    linequery = char(Serial.read());   //Read the file
    Serial.println(linequery);            //Print the file (For checking purpose only)
return (linequery);
I'll be using the return value of method query for this:
if (linequery == '0')
            sms.SendSMS(number, "abc");
          else if (linequery == '1')
            sms.SendSMS(number, "def");
          else if (linequery == '2')
            sms.SendSMS(number, "ghi");
          else if (linequery == '3')
            sms.SendSMS(number, "jkl");
But after returning the value of the read file to arduino, it always gets 0. I think, somehow, the arduino misinterpret the data. I also thought it might be the data type that I am using for linequery. Any suggestions/idea/solution? Please help. thanks!
Here is a photo of the Gobetwino serial monitor.
astrofrostbyte
I feel like I'm missing something,  like some background info ?
Gear: Arduino- Uno,Due,Ethernet,  OLS, Buspirate, J-Link, TDS1002, Rigol DG1022
scholarium
Oh, I'm sorry.
I am using a php file in editing and putting values on the text files. That query.txt may contain 0,1,2 or 3. Here's one part of my code:
$openquerycmd = fopen("query.txt","w");
$sendquerycmd = fwrite($openquerycmd, '3');
fclose($openquerycmd);
After that, the value of query.txt should be 3. But after execution of RLFIN and returning the value to arduino, it always prints 0.
Particularly what data type is it of a text file? char? string?
I don't know if that is the background you are asking. Sorry, noob here @.@
Nick Gammon
Can we see the whole sketch please? In code tags? How to use this forum
Once you call "query", how do you know if serial was available? Is linequery just some undefined value then?
More info:
scholarium
Here it is:
#include "SIM900.h"
#include <SoftwareSerial.h>
#include "sms.h"
SMSGSM sms;
boolean started=false;
char position;
char read;
char message[160];
char number[20];
char linequery;
String errormsg;
char error[160];
char ticket;
String successtxt;
char txtgen[160];
  if (gsm.begin(2400))
    Serial.println("\nstatus=READY");
    started=true;
    Serial.println("\nstatus=IDLE");
char query()
return (linequery);
char* stockerror()
  Serial.println("#S|STOCKERR|[1]#");
      errormsg = String(Serial.read());
      errormsg.toCharArray(error, 160);
      Serial.println(error);
return (error);
char* orderticket()
  Serial.println("#S|TXTGEN|[1]#");
      ticket = char(Serial.read());
      successtxt = "Order successful! Your ticket order is: ";
      successtxt += ticket;
      successtxt.toCharArray(txtgen, 160);
      Serial.println(txtgen);
return (txtgen);
  if(started)
    position = sms.IsSMSPresent(SMS_UNREAD);
    read = sms.IsSMSPresent(SMS_READ);
      if(position == 1)
        sms.GetSMS(position, number, message, 160);
        Serial.print("#S|VERIFYNUM|[");
        Serial.print(number);
        Serial.println("]#");
        Serial.print("#S|MSGLOG|[");
        Serial.print(message);
        Serial.println("#S|STARTPHP|[]#");
        query();
            sms.SendSMS(number, "This is Piyeshop query and ordering  system. For more info, visit thesis.lezworld.com.ph");
            sms.SendSMS(number, "Your query is invalid. Please refer to the ordering manual.");
            sms.SendSMS(number, stockerror());
            sms.SendSMS(number, orderticket());
      else if(position > 1)
        for(int i = 1; i <= position; i++)
          query();
  sms.DeleteSMS(read);
  delay (10000);
PaulS
char query()
return (linequery);
Why does this function return a global value? Why is the variable in parentheses in the return statement? Why did you feel it necessary to cast the value from Serial.read() to a char?
How useful. A one character error message.
That is then extracted and stored in a 160 character array.
return (error);
Another function that returns a global variable.
You are going to run out of ticket numbers after you sell 10 tickets, if the first one is 0.
You are pissing memory away right and left. On a platform with 2048 bytes of memory, that is really not a good idea. Get rid of EVERY instance of the String class, and learn to do it like a big boy - using the char arrays without crutches.
Nick Gammon
To put it a bit more gently ...
Please note that, at present, the String library has bugs as discussed here and here.
In particular, the dynamic memory allocation used by the String class may fail and cause random crashes.
I recommend reworking your code to manage without String. Use C-style strings instead (strcpy, strcat, strcmp, etc.), as described here for example.
Alternatively, install the fix described here:  Fixing String Crashes
Also you might want to read: http://www.gammon.com.au/serial
More info:
scholarium
Sorry. >.< I just said I am noob. Well, thanks btw. Still didn't get the answer to what I am asking.
scholarium
I have a php code which will log 0, 1, 2, or 3 to a text file (Query.txt). After execution, the value is successfully logged on the txt file. I have then an arduino code which prints #S|QUERY|[1]# to command gobetwino to read query.txt. it is successfully read and then returns a value to arduino using variable linequery. I have then a serial.println(linequery) and it prints a value of 0 instead of the right value. More confusing is that the command output window in gobetwino prints the right value. What do you think is the problem? Can someone help me? thanks!
Coding Badly
Please don't cross-post.  Topics merged.
PeterH
The rule you have set up in Gobetwino causes it to send a line of text when you send it the command string. However, your code only reads back the first character of any response.
You need to keep reading from the serial port until you have received the complete response line.
I only provide help via the forum - please do not contact me for private consultancy.
scholarium
Peter, I don't have any idea how to do that. Can you give some example? Is it some sort of an EOF command?
PeterH
You need to keep reading from the serial port until you have received the complete response. Typically that would be a line of text terminated by a carriage return and/or new line character. So you can simply keep reading until you receive one of those. The code could look something like this:
const int buflen = 80;  // length of the longest line you expect to receive
char buf[buflen];
int len = 0;
if(Serial.available())
    char c = Serial.read();
    if((c == '\n') || (c == '\r'))
        if(len > 0)
            handleCommand(buf);
            len = 0;
        if(len < buflen)
            buf[len++] = c;
            buf[len] = 0; // append null terminator
scholarium
Peter, I already got it by using while loop until he gets the last byte whenever serial is available. but here's another problem. the serial.read() seems to read the previous logs on the serial. that's why when the serial is initially null, the first process returns null. the second process returns the output for the first process. and consecutively for the next processes. can u help me out?
