Your diagram shows that you have got pull-down resistors in place so you do not have floating inputs. (I assume these resistors are in place for all four inputs used by your sketch.)
I think the problem is that these conditions are not all mutually exclusive:
if (P1State == HIGH)
if (L2State == HIGH)
if (L1State ==HIGH)
if (L2State ==HIGH && P1State==HIGH)
This means that even if you correctly turn the outputs off in one piece of code, they could be turned on again by another piece of code.
I suggest you restructure so that they are mutually exclusive and the precedence between them is defined explicitly, e.g.:
if (L2State == HIGH && P1State == HIGH)
if (L1State == HIGH)
