Loading...
Pages: [1]   Go Down
Author Topic: Driving 7 Segment led's  (Read 491 times)
Offline Offline
Newbie
View Profile
                           Hi all, i have a project i'd like to get going, i have over googled and am dizzy ! so a little help would be great. i'm looking for the best way to drive 4 7 segment led's. i have seen a few units that are pre-made, great! but i'd like to make my own and plus they didn't provide a schematic or chip info. I'd like to use it as a voltage display for my psu and later as a text display for other arduino project's. would be nice if i could use it like a "backpack" display
Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
in a nut shell its 7 led's that share the same cathode (- side) then you multiply it by how many digits
so if you have a 4 digit display you will have 7 or 8(decimal point) pins going to led's and 4 cathodes
the magic trick is to display them 1 number at a time, quick enough that you cant see them blink on and off
doing this can be direct to arduino, or you can use some shift registers
http://arduino.cc/en/Tutorial/ShiftOut
or any other million and one ways to tackle the problem, each with their advantages and disadvantages ... for instance shift registers cant provide much current so your limited to a rather dim display, especially if each number is only on for 1/4 the time
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
I'm looking into this too, and am leaning towards using SPI and the MAX72XX chip as explained in the playground.
Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Offline Offline
Newbie
View Profile
i think the max is the most popular way i've seen (youtube) everything else has a ton of wiring i'd like to avoid !! spi,i2c anything would be great to save pins for other task.
Logged
Offline Offline
Full Member
View Profile
I did one project using Max7219 with 5 7-segment displays, with a PIC16F628A. It is easy to grasp, just follow the document.
Logged
Search for "mjkzz" on eBay :-)
Eugene, Oregon
Offline Offline
Sr. Member
View Profile
WWW
Like most LED projects, there are many ways to accomplish the same task.
If you include any possible limitations, that makes it easier to choose one method over another.
Your more common options are:
Multiplexing
Charlieplexing
Constant Current Drivers
Shift registers
Transistors.
If adding parts or complexity is a problem, then multiplexing or charlieplexing might be a good option.
If brightness is a primary concern, then mutiplexing or charliplexing are less optimal, and constant current or shift registers might be a better option.
If your LEDs are under 9ma each, and you must use shift registers, then the 74hc595 shift registers will probably be ok, if you need 20ma, you will want TPIC???? shift registers as the hc595s are limited to 70ma.
There are probably ways that I havnt even mentioned... You may want to try them all... its possible to try each way, and see what you like best.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Here's one way to drive 4 displays as a standalone project.
The TPIC6B595 is a nice driver because it can also control segments that are 3-4-5 LEDs in series and powered by 12V, and can sink more than 20mA per pin continuously.
74HC595 is only good for 5V and not much current as pointed out.
Easy to send data to:
Code:
// define these in pre-setup code
byte dataArray[] = {digit0,digit1,digit2,digit3};  // data that will be displayed
byte fontArray[] = {  // fonts that make up the numbers, 1 is an On segment
B00111111, // 0        a
B00000110, // 1    f        b
B01011011, // 2        g
B01001111, // 3    e        c
B01100110, // 4        d       DP
B01101101, // 5
B01111101, // 6
B00000111, // 7
B01111111, // 8
B01101111, // 9
B00000000, // Off 0x0A
// data is stored in an dataArray[], update when needed then call this code:
digitalWrite(ssPin, LOW);
for (x=0; x<4; x=x+1){
SPI.transfer(dataArray[fontArray[x]]);
digitalWrite(ssPin, HIGH; // data changes on this rising edge
« Last Edit: March 08, 2013, 04:23:11 pm by CrossRoads » Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Pages: [1]   Go Up
Print
Jump to:
