Topic: ERRO IN SERIAL bluettoth program (Read 458 times) previous topic - next topic
nstm91
Mar 08, 2013, 08:35 am Last Edit: Mar 08, 2013, 12:14 pm by nstm91 Reason: 1
i instil library of  newSoftSerial in arduino lib...
and try to verify serial program but it display some error
and it display this error
In file included from serial.ino:4:
C:\Documents and Settings\suresh\My Documents\Arduino\libraries\GSM_Shield/NewSoftSerial.h:71: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
I:\arduino-1.5.2-windows\arduino-1.5.2\hardware\arduino\avr\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
and attach code here...
AWOL
The code you posted is Processing.
Please use code tags when posting code.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
AWOL
Code: [Select]
#include <SoftwareSerial.h>
#define RxD 2
#define TxD 3
SoftwareSerial blueToothSerial(RxD,TxD);
    Serial.begin(9600);          //Serial port for debugging, Comment this line if not required
    pinMode(RxD, INPUT);
    pinMode(TxD, OUTPUT);
    setupBlueToothConnection();
  if(blueToothSerial.read() == 'a')
    blueToothSerial.println("You are connected to Bluetooth Bee");
    //You can write you BT communication logic here
void setupBlueToothConnection()
    Serial.print("Setting up Bluetooth link");       //For debugging, Comment this line if not required
    blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
    sendBlueToothCommand("\r\n+STWMOD=0\r\n");
    sendBlueToothCommand("\r\n+STNA=modem\r\n");
    sendBlueToothCommand("\r\n+STAUTO=0\r\n");
    sendBlueToothCommand("\r\n+STOAUT=1\r\n");
    sendBlueToothCommand("\r\n+STPIN=0000\r\n");
    delay(2000); // This delay is required.
    blueToothSerial.print("\r\n+INQ=1\r\n");
    Serial.print("Setup complete");
void sendBlueToothCommand(char command[])
    char a;
    blueToothSerial.print(command);
    Serial.print(command);                          //For debugging, Comment this line if not required
    delay(3000);
    while(blueToothSerial.available())              //For debugging, Comment this line if not required
    {                                               //For debugging, Comment this line if not required
       Serial.print(char(blueToothSerial.read()));  //For debugging, Comment this line if not required
    }                                               //For debugging, Comment this line if not required
compiling gave the error message
Quote
Binary sketch size: 4984 bytes (of a 14336 byte maximum)
nstm91
Code: [Select]
#include <NewSoftSerial.h>   //Software Serial Port
#define RxD 2
#define TxD 3
NewSoftSerial blueToothSerial(RxD,TxD);
    char a;
    delay(3000);
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
