Topic: Motor shield broken? (Read 948 times) previous topic - next topic
Kontsnor
Hi all, I´ve been using an Arduino for a while now, but I´m running into some problems.
I got a DFRobot motorshield (http://www.dfrobot.com/wiki/index.php/Arduino_Motor_Shield_(L293)_(SKU:_DRI0001)) connected to my Arduino, and 2 lego motors to the shield. I connected the shield and motors just the way it should, so there is no problem there.
Whenever I set the directional port of Motor 2 (pin 4) to LOW, the motor doesn't do anything. If I do the same for Motor 1 (pin 7) the motor does turn the other way.
My best bet is that the shield is broken, but I'd like to know what you guys think.
JimboZA
Have you swopped the motors onto each others' pins?- that way you could check if it's the board or the motor.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Kontsnor
Yep, tried that. Then the other motor gives me problem. So the motors are fine. It isn't the Arduino either, because when I tried the same sketch (Dfrobot demo code) with another Arduino, I got the same problem. Guess I gotta get a new shield  :smiley-roll-blue:.
dfrobot
Can you show your connection diagram?  We will try to help you solve the problem.
DFRobot-Drive The Future
Official Technical Support for DFRobot Product
www.DFRobot.com
