Loading...
Pages: [1]   Go Down
Author Topic: programming Arduino remotely via XBEE  (Read 1152 times)
Offline Offline
Newbie
View Profile
I am trying to remotely program an Atmega328 with UNO bootloader using an XBEE.   For the reset line, I use XBEE's I/O line passing, with the programming done via the XBEE's serial link.  The /RST, TX, and RX signals at the transmitting XBEE and remote Arduino show proper levels and polarity.  But I get an error message (a sync error after 3 retries) when trying to program it using Arduino's AVR to write to the transmitting XBEE.  On other projects that are programmed in the usual way, I have seen this message when there was a problem with reset levels or timing.
Does anyone know of either:
1) a way to program Atmega328s remotely via XBEE
or
2) a reference document for the bootloader/AVR with a description of the loading process, especially timing and state diagrams?
  • I am using the most recent releases of Arduino and bootloader.
  • Programming was tried at 9600 and 57600.  XBEE to XBEE communication was fully verified at both baud rates, but with no programming success.
  • Reset at remote XBEE came from an I/O  thru a 0.1uF cap to the /RST pin pulled up with 10K.  A direct connection between XBEE and /RST was also tried.
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Which XBees are you using?
Logged
Offline Offline
Newbie
View Profile
I am using series1 XBEEs (not ZIGBEE).
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
All the tutorials I've seen that claim that wireless programming of the Arduino is possible used Series 2 models.
Logged
Offline Offline
Newbie
View Profile
There are instructions for programming via series 1 XBEEs like Adafruits' http://www.ladyada.net/make/xbee/arduino.html.  This is identical to what I have been trying to do, except Adafruit only got it to work with the Duemilanove bootloader and I need to make this work with the UNO bootloader - or at least understand why it doesn't.  That's why I was looking for documentation on that bootloader.  I want to compare my scope traces with the bootloader's protocol and timing requirements.
If anyone has been able to remotely program an Atmega328 with UNO bootloader via series 1 XBEE, I could use some advice.
Logged
Offline Offline
Newbie
View Profile
Found the problem and solution:
Series 1 XBEEs seem to get unreliable above 57600 bps in my tests.  And the UNO bootloader runs at 115200 bps with no option of changing that speed.  Using Adafuit's bootloader https://www.adafruit.com/products/123 everything runs well at 57600 bps.  Now the procedure on this page http://www.ladyada.net/make/xbee/arduino.html works.
Logged
Pages: [1]   Go Up
Print
Jump to:
