I bought the uLCD-32PTU (
https://www.sparkfun.com/products/11677?) and it worked fine using it as a slave with Aduino uno R3 and mega 2560, but I have problems with the Arduino due. I explain: I first loaded the Serial Library for the Picaso (
https://github.com/4dsystems/Picaso-Serial-Arduino-Library) to Aduino's library folder then loaded this code to an arduino uno:
#include <Picaso_Serial_4DLib.h>
#include <Picaso_Const4D.h>
#define DisplaySerial Serial
Picaso_Serial_4DLib Display(&DisplaySerial);
void setup(void){
pinMode(2, OUTPUT);
DisplaySerial.begin(9600) ;
Display.TimeLimit4D = 5000 ;
digitalWrite(2, HIGH);
delay(100);
digitalWrite(2, LOW);
delay(3000);
Display.gfx_Cls() ;
Display.putstr("Hello World\n") ;
void loop(void){
Then connected power, ground RX and TX to the arduino uno, it worked fine (see pictures 1 and 2).
Then I connected and Arduino mega uploaded the same code and it worked fine.
Then I connected an Arduino due uploaded the same code, but there is problem, there are no serial communication on the Serial port and no display on the LCD screen. I am wondering if there is a problem bettween the Serial library for the Picaso and the Arduino due... (I hope I did not make a stupid mistake, pictures 3 and 4 might help).
Thank you in advance for your help.
Francois
PS: if your webbrwoser does not show the pictures, you can find them here:
http://4d.websitetoolbox.com/post/Arduino-Due-problem-with-Serial-Library-6242552?pid=1277180252#post1277180252
