Topic: Composite Video Generating (Read 21433 times) previous topic - next topic
Gericom
Colors:
Subscribe my youtube channel: http://www.youtube.com/user/MKDS3
Markus_L811
Gericom
Yes really impressiv work.
Thanks! It will even become better when I change the resistors of my R2R ladder. They're a bit too high, so that's why the pictures are a bit dark. Here is another picture:
Gericom
NSMBU worldmap (aka little details):
Gericom
I just tested on a real tv, and it looks very nice! No color errors and such. Keep in mind that it works with a framebuffer, so you can draw on it in runtime. And you can use every color you want!
Gericom
I've added a video op-amp, and the brightness is much better now.
Gericom
I made the wss working again:
Gericom
Another widescreen picture in the right proportions:
Gericom
Proof of concept video:
http://www.youtube.com/watch?v=ecU-Zi--jNw
(please subscribe)
brendanwilding
This is so cool, well done!
I would love to see some more information about wiring etc.
Gericom
Thanks!
It is a r2r ladder (kind of) and a video op-amp (which you can get for free). That's it.
Gericom
I have started working on this a few days ago, and the video op-amp is not needed anymore now. It turned out that the the voltage ratios were not correct. I fixed it, and in combination with a new and better r2r ladder, it works much better. I also switched from 8 to 5 bits, cause that's just more suitable for a 1% r2r ladder.
There are still some color phase errors, but since pal uses phase alternation, those errors are not much noticable.
BlackSnake
Hi There.
I just got myself an Arduino due today and thought what better way to try it out then with your cool graphics :)
Do you have a library ? or any code I can run. Possibly a circuit diagram if it's not to much trouble of course.
You did a fantastic job on your project, well done
Thanks
BlackSnake
Gericom
Hi There.
Thanks
BlackSnake
Thanks, I have a sketch you can run (it consists out of multiple files) and I will make a schematic. I will do this when I have time to do so.
mano1979
Any update on your code and wiring? I'd love to try this!
Gr. Uit Amsterdam
