Topic: Composite Video Generating (Read 20735 times) previous topic - next topic
Gericom
I am working on generating composite video with the due. It uses the dac, and it works great already. I will post some photo's tomorrow.
Subscribe my youtube channel: http://www.youtube.com/user/MKDS3
Gericom
#1
Mar 09, 2013, 02:18 pm Last Edit: Mar 09, 2013, 08:11 pm by Gericom Reason: 1
Here are some pictures. (Yes, I use a camera as tv screen, since I have no tv in my room) The generated signal is 150x287, and uses 'fake' progressive: It only outputs one field.
Edit: ATM I am trying to get color working.
Gericom
Hmm, implementing color seems to be very hard. I don't understand what I need to generate from the RGB values. Since there is a color burst + the signal itself.
stimmer
Be careful about connecting the output of the DAC directly to a video input, as video inputs usually have a low impedance (75 ohms) and some of us have broken our DACs by connecting them directly to low impedance loads. Use a buffer amplifier or emitter follower.
Generating colour is very complicated. The colour subcarrier needs to be at a very specific frequency (3.579545 MHz for NTSC or 4.433619MHz for PAL) and I doubt the DAC can go that fast.
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
Gericom
I have it connected to my scope too (which has 1M impedance). But anyway, I could try making a R2R ladder or something. That would be much faster. But I am not sure if I have the right resistors.
Markus_L811
I'm right yo you must have all parallel connected, so the smalest resistor will beat all other if you connect it and messure the impedance value you will get ~75 Ohm even with the 1M impedance. God will be an operational amplifire as voltage follower between the DAC and the rest of the connections or something else how has an high input impedance and an low output impedance.
stimmer
The more I think about this the more I wonder if it might actually be possible - an R-2R ladder on the external memory pins (34-41) together with DMA should work reliably at 10.5MSPS and may even go as high as 21 or 28MSPS (I learned that doing the VGA library). The dealbreaker would be how close to the exact colour subcarrier frequency you have to get. In my experience, with old CRT TVs you have to be very accurate, but more recent LCD panels have more tolerance for the frequency and amplitude of the colour subcarrier being wrong.
Gericom
#7
Mar 17, 2013, 08:32 pm Last Edit: Mar 18, 2013, 05:26 pm by Gericom Reason: 1
That would be awesome, but first I need to add an op-amp to my ladder, otherwise the signal drops when connecting to my camera. Can you give me some lm#### ic numbers?
Edit: I ordered some samples of the AD811 (http://www.analog.com/en/all-operational-amplifiers-op-amps/operational-amplifiers-op-amps/ad811/products/product.html). It seems to be a good one. I hope I will get them in a week or 2.
Gericom
#8
Mar 19, 2013, 03:49 pm Last Edit: Mar 19, 2013, 05:36 pm by Gericom Reason: 1
I got it working on my r2r ladder without an op-amp now (I mean the signal b/w not color yet). I only needed to change the pin numbers.
Can someone tell me how to add dma?
stimmer
I've just found some resistors for an R-2R ladder but they are only 1% tolerance. I was going to measure them more accurately and select some for the ladder, otherwise things start going wrong after 5 bits. Even then I think there will be too much noise on the digital outputs for full 8 bit accuracy. I'll see how well I can do.
DMA for the external memory port is quite hard to set up as it is AHB DMA - I use it in the VGA library but the code is impossible to follow  :smiley-mr-green: I'll try and do a simpler example once I've got the ladder done.
Gericom
#10
Mar 19, 2013, 06:07 pm Last Edit: Mar 19, 2013, 06:08 pm by Gericom Reason: 1
I have 8 bit now. With 5% tolerance. (R is 10K each. I use 2 of them for the 2R. I know that this resistor is a bit too high)
Hmm, too bad. Isn't dma just setting a source and a destination pointer? On the ds for example there are functions like these:
void MI_DmaCopy32(u32 dmaNo, const void *src, void *dest, u32 size);
Which you use like this:
MI_DmaCopy32(3, &px[0], VramPixels,512 * 192);
Aren't there such functions on the due?
Gericom
Here is an example of a picture generated with the due. (It is captured in jpeg using the camera I use for viewing it, so not the best quality)
stimmer
With 5% resistors the R-2R ladder may lose too much accuracy. 5% of 255 is almost 13 which is a 4-bit number, so you could lose 4 bits of accuracy out of the 8, which is too much. Try connecting the analog output of the ladder to an analog input on the Due, then write a sketch which outputs 0-255 onto the ladder and reads the value on the analog input. You might find that the ladder isn't monotonic (sometimes when the input goes up by 1 the output voltage goes down instead of up).
THe DMA needs to be continuous (a bit like an audio buffer would be, just a lot faster)  which is why it's more complicated than just DMAing blocks of memory.
Gericom
#13
Mar 19, 2013, 07:56 pm Last Edit: Mar 19, 2013, 08:05 pm by Gericom Reason: 1
Yea, but it works good enough for now. I will use other resistors (1%) later on.
Oh, okay. I realize how it need to work now. I will try to understand your code, since I only need to change the frequency and the source pointer.
stimmer
Here's the sketch I used to check my ladder:
char pins[]={34,35,36,37,38,39,40,41};
void writeval(int v){
  for(int i=0;i<sizeof(pins);i++){
    digitalWrite(pins[i],v&1);
    v>>=1;
  analogReadResolution(12);
    pinMode(pins[i],OUTPUT);
  int l=0;
  for(int i=0;i<(1<<(sizeof(pins)));i++){
    writeval(i);
    delay(10);
    int m=analogRead(0);
    printf("%d : %d  d=%d\n",i,m,m-l);
    if(m<l)printf("!!!!!!ERROR!!!!!!!!!! non-monotonic\n");
    l=m;
  delay(2000);
If you get errors then just swap the resistors around until they go away.
