Topic: Arduino UNO and Mac Mountain Lion problem (Read 2473 times) previous topic - next topic
arockmez
Mar 08, 2013, 08:05 pm Last Edit: Mar 08, 2013, 08:07 pm by arockmez Reason: 1
Hello people:
I'm new in this forum...i switched from Windows to Mac (Macbook Pro with 10.8.2 OS X) some weeks ago and i'm having problems setting up my arduino board. I got an Arduino UNO with ATmega328 but i can't upload sketchs to my board...
First problem is that i can't find "Uno" on Tools>Board (i'm using the latest software) and i'm using instead "Arduino Duemilanove or Nano w/ATmega328. My arduino is on with the green and orange LEDs but i just can't upload anything. In Tools>Serial Port i selected /dev/tty.usbmodem1411 and when i try to upload something the orange LED and rx LED blink but nothing comes after...i got this message when trying to upload the Blink sketch:
Binary sketch size: 1008 bytes (of a 30720 byte maximum)
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0xe0
Thank you for helping me
Greetings!
StereoBucket
arockmez
i already tried and nothing happens...i tried rebooting the mac too :(
StereoBucket
Try changing the USB ports.
Try other ports and see if it works.
arockmez
#4
Mar 08, 2013, 08:30 pm Last Edit: Mar 08, 2013, 08:33 pm by arockmez Reason: 1
Arduino doesn't work in any port :( one of the USB is connected to a 2.0 hub (Macbook USB are 3.0), i read Arduino could have problems with hubs so i used the other USB with no success. Thank you for helping me!
Edit: I tried using a 2.0 adapter in the free USB port and nothing changes
StereoBucket
http://arduino.cc/en/Guide/MacOSX
Did you use this tutorial?
arockmez
Yes, i saw that guide while installing my board, i downloaded the software with those links but i can't get the "Arduino Uno" option and i have all the problems listed above
StereoBucket
You don't have arduino Uno?
Can you take a screen shot of the boards you have in the board list in arduino IDE?
arockmez
okay, give me a second :) ill take some photos of the board too
StereoBucket
Well the more the better.
Pic of the board and the list of the devices in tools/boards.
arockmez
Here they are :D
http://imageshack.us/photo/my-images/5/capturadepantalla201303t.png/
http://imageshack.us/photo/my-images/545/capturadepantalla201303em.png/
http://imageshack.us/photo/my-images/836/img6575b.jpg/
http://imageshack.us/photo/my-images/17/capturadepantalla201303l.png/ (i don't know what's the boot loader, but maybe it could help)
http://imageshack.us/photo/my-images/839/capturadepantalla201303lu.png/
StereoBucket
#11
Mar 08, 2013, 09:03 pm Last Edit: Mar 08, 2013, 09:06 pm by StereoBucket Reason: 1
Bootloader is something that is written in the boot section or the first several bytes of the flash memory and is used to upload your sketches to the arduino via USB and Arduino IDE.
By the way.
It looks to me like it's a bit outdated.
My arduino IDE has a lot more boards than yours.
Try redownloading the Arduino IDE.
http://arduino.googlecode.com/files/arduino-1.0.3-macosx.zip
Also
try this code
Quote
 Blink
 Turns on an LED on for one second, then off for one second, repeatedly.
 This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
// the setup routine runs once when you press reset:
 // initialize the digital pin as an output.
 pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
 digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
 delay(1000);               // wait for a second
 digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
spatula
Looks like version 0019 to me.
@arockmez I would recommend version 1.0.3 unless you need support for the Due.
arockmez
Thank you so much, ill try both and ill tell you what i got...i think the problem is my software because as i remember i downloaded it from spanish version of arduino website and when i download the software in the english website i get another version or at least a file with another name...ill try it and i think it will solve the problem because i realized spanish website is out of date. Thank so much! as the download finishes ill post something
StereoBucket
Yeah looks like you got Beta version made for Due.
Download that one in the link i gave you.
