Loading...
Pages: [1]   Go Down
Author Topic: How can I attach a crank like this to a motor like this?  (Read 666 times)
Offline Offline
Jr. Member
View Profile
Here is the setup I'm going for:
Here is my motor:
http://www.ebay.com/itm/280875300072?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
What kind of connections do I need to make this happen?
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
Looks like a lot of improvisation (wood, tape, hot-melt glue...)
You can, too!
Logged
Don't Be Upset By The Results You Didn't Get With The Work You Didn't Do
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Looks like maybe hot glue.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Edison Member
View Profile
They are 1.3V, are you using a 5V Arduino ? Why would you use 1.3V motors ?
They are 18000 rpm, why would you want to wiggle the tail with 18000 rpm ? Is it a very fast fish ?
Can you use a servo ?
Logged
South Texas
Offline Offline
God Member
View Profile
Any hobby shops near you that have Model Airplane supplies? They have thins like small shaft collars that are made of brass, and brass plate. You could solder the shaft collar to a piece of brass plate and then (using the set screw in the shaft collar) mount the crank to the motor.
Hey guys - nice of you to offer useful answers and ideas to the question that was asked.... Try to be helpful, not just geniuses...
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
You interpreted differently than "we" did.
That's OK.
If he wanted to do it like the picture, we gave our take on that ("Improvise, that's how we won the war.")
Anybody can go spend money.
> > > I *heart* JBWeld !
« Last Edit: March 05, 2013, 01:27:17 pm by Runaway Pancake » Logged
Offline Offline
Jr. Member
View Profile
Thanks for the tips. I guess a big question I have that I didn't explicitly ask is: how do you attach things to the motor shaft (or whatever the rod sticking out of it is called)?? It is totally smooth so it doesn't make sense to me how one would connect something. I would also love to just extend the rod like 8 inches (shuttup) so how would I do that? Do I remove the shaft that is already there and replace it or is there an adapter?
Logged
Offline Offline
Edison Member
Now, More Than Ever
View Profile
Thanks for the tips. I guess a big question I have that I didn't explicitly ask is: how do you attach things to the motor shaft (or whatever the rod sticking out of it is called)?? It is totally smooth so it doesn't make sense to me how one would connect something. [...] Do I remove the shaft that is already there and replace it or is there an adapter?
The drawing at the ebay link shows the shaft diameter is "0.8"
I guess it's the French system (mm)
Most couplers (hubs, bushings) I've seen are for 2mm, 3mm, 4mm
http://banebots.com/c/WHB-HM-HS4
Logged
Denmark
Offline Offline
God Member
View Profile
WWW
These small motors (called pager motors) are used in micro airplanes, and usually the propellor is just a press to fit solution.
Make a 0.5 mm hole in the material you want to use, and press it on the shaft.
Quote
  smiley-grin
A good one, I think the only country still using Inches is  USA   smiley-lol
« Last Edit: March 06, 2013, 10:23:46 am by Erni » Logged
SW Scotland
Offline Offline
Edison Member
Arduino rocks
View Profile
If you are not transmitting a lot of torque you could actually use a short length of fine bore rubber tubing as a shaft coupling. If necessary a small drop of super-glue can be put into the tube bore to enhance the grip  -  just make sure it doesn't get into the motor internals !
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
If you were really crafty, and had a way to keep the shaft from turning (or could remove the armature from the motor), you could thread the shaft with the right miniature die (you could probably find a miniature tap and die set here: http://www.micromark.com/). Then, tap the part you're wanting to mount, and thread it on (maybe with a small bit of thread lock).
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
  smiley-grin
Well the UK is mainly switched to metric in technical/engineering areas now except for legacy applications,
but things like beer units and road speed are still imperial (political conservatism).  People
commonly use a mix of metric and imperial in everyday use now.  SI will prevail everywhere in the long term I
think just because
1 - The convenience of almost no conversion factors needed (consider calculating horse-power from torque
     in foot-pounds and RPM - in SI power = torque * frequency * 2pi
2  The fact electrical units are already SI and directly tied to the metre/newton/joule/watt.  For instance farads
    are a shorthand for columbs-squared-per-joule, volts are watts-per-amp, volts-per-metre = newtons-per-coulomb.
Logged
Offline Offline
God Member
View Profile
Farads are coulombs per volt.
Logged
Pages: [1]   Go Up
Print
Jump to:
