Topic: DS18B20 - Round Temperature (Read 3594 times) previous topic - next topic
gnusso
Hi All,
I'm using DS12B20, with the example I've the temperatura displayed like this :
12.23
20.37
etc etc
I would like to round the temperature for example see:
12.20
20.40
Is possible ? Thanks for the information,
Gnux
UKHeliBob
Is http://playground.arduino.cc/Code/PrintFloats any help ?
gnusso
Ciao UKHeliBob,
Thanks you for the link, I've play a little bit with it ... but I would like print on my display and not on Serial ...
But is not possible to pass printFloat() function to LCD.print() function ...
any other ideas ?
I was thing to convert in string and then take left string could be possible ?
Regards,
Andrea
PaulS
Which LCD library are you using? Does it derive from the Print class?
gnusso
i'm using LiquidCrystal.h
Regards,
Gnux
robtillaart
round the number e.g. by moving to integer domain.
pseudo code
float temp =12.34
int t = temp * 10 + 0.5;  // t = 123   (.9)  t is temp in tenths
print t/10;  // integer part
print .
print t%10;  //decimal part
print 0;
(if temp < 0 code might differ slightly)
Rob Tillaart
PaulS
From LiquidCrystal.h:
class LiquidCrystal : public Print {
So, LCD.print(someFloat, 1);
will show someFloat on the LCD rounded to one decimal place.
robtillaart
Rob Tillaart
gnusso
Thanks Guys for the suggest,
I will try and then I'll let you know ...
Have nice week end,
Gnux
gnusso
Yes It's working with the round suggest by Paul !
Thanks you again,
Regards,
Gnux
UKHeliBob
Does it round or does it truncate ?
robtillaart
from print.cpp
// Round correctly so that print(1.999, 2) prints as "2.00"
  double rounding = 0.5;
  for (uint8_t i=0; i<digits; ++i)
    rounding /= 10.0;
rounding it does
Rob Tillaart
