Loading...
Pages: [1] 2 3 4   Go Down
Author Topic: help with alarm code  (Read 711 times)
0
Offline Offline
Sr. Member
UNO
View Profile
hi all...
i just foun this code but maybe im not editing it right....
what i want with the code its ust to simple post a tweet every time my led turns high....
but have many troubles, for example the code just post when i open serial monitor, second when i change the code for the led input, then it doesnt post anything,
and last, its that twitter does not acept my msg cos it said its the same tweet, so how can i change that
Code:
#include <SPI.h> // needed in Arduino 0019 or later
#include <Ethernet.h>
#include <Twitter.h>
// The includion of EthernetDNS is not needed in Arduino IDE 1.0 or later.
// Please uncomment below in Arduino IDE 0022 or earlier.
//#include <EthernetDNS.h>
const int ledPin = 3;
int ledState = LOW;
// Ethernet Shield Settings
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// If you don't specify the IP address, DHCP is used(only in Arduino 1.0 or later).
byte ip[] = { 192, 168, 2, 250 };
// Your Token to Tweet (get it from http://arduino-tweet.appspot.com/)
Twitter twitter("1220261654-BPUYlMFTyfs5ooSFSA62C57Ujeqnr9hdn7PARZm");
// Message to post
  pinMode(ledPin, INPUT);
  Ethernet.begin(mac);
  // or you can use DHCP for autoomatic IP address configuration.
  // Ethernet.begin(mac);
  Serial.println("connecting ...");
  Serial.println(ledState);
  char msg[]="que odes";
  if (ledState == HIGH)
  int cont=0;
  if (twitter.post(msg)) {
    // Specify &Serial to output received response to Serial.
    // If no output is required, you can just omit the argument, e.g.
    // int status = twitter.wait();
    int status = twitter.wait(&Serial);
    if (status == 200) {
      Serial.println("OK.");
      Serial.print("failed : code ");
      Serial.println(status);
    Serial.println("connection failed.");
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Code:
Your code never reads or changes ledState.
Logged
0
Offline Offline
Sr. Member
UNO
View Profile
so if i attacht it to an interrupt and read the rising, the arduino will know that, i see that error, thanks, but how can i change that arduino knwos that state and post the msg without open the serial monitor???
Logged
Chicago
Offline Offline
Jr. Member
Arduino rocks
View Profile
Where is the attacthinterrupt at I see nothing for setting up or handling an external interrupt.
Logged
0
Offline Offline
Sr. Member
UNO
View Profile
i still have no posted the changes that NIck suggested....
Logged
Chicago
Offline Offline
Jr. Member
Arduino rocks
View Profile
In setup you need to attachinterrupt with some parameters. See link for learn to use that function.
http://arduino.cc/en/Reference/AttachInterrupt
Logged
0
Offline Offline
Sr. Member
UNO
View Profile
i know how to do that, the problem is that i cant change how to post a msg without opening the serial port
Logged
California
Offline Offline
Edison Member
View Profile
Why do you think you need an interrupt?
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Huh? Where is your changed code?
Logged
Chicago
Offline Offline
Jr. Member
Arduino rocks
View Profile
Try this out there is no debounce of the pin Interrupt 0 is digital pin 2 on the Uno baord
Code:
//const int ledPin = 3;
int ledState = LOW;
// you shouldn't post your token we could post on your Twitter account with this info...
// Message to post
  digitalWrite(2, HIGH); //turn on internall pullup resistor
  attachInterrupt(0, ExtInt0Fall, FALLING); // there is no debouce of this pin
      ledState = LOW;
      int cont=0; // ? what is this for??
      Serial.println("High now");
          if (status == 200)
void ExtInt0Fall()
  ledState = HIGH;
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Better read this:
http://www.gammon.com.au/switches
There is no debounce because you haven't coded in a debounce.
Logged
Chicago
Offline Offline
Jr. Member
Arduino rocks
View Profile
Nick I made that for him to try, when it posts to Twitter that will take a little bit of time
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Oh I see, sorry. I mistook you for the OP. smiley
You are right, the sending will debounce.
Logged
0
Offline Offline
Sr. Member
UNO
View Profile
Code:
int ledState = LOW;
// Message to post
      ledState = LOW;//[color=red]this turns the led off???[/color]
      int cont=0; // ? what is this for??//[color=red]this was meant tobe a counter to print it with the msg so the msg could change and twitter did not give error[/color]
          if (status == 200)
void ExtInt0Fall()
  ledState = HIGH;
the problem im still trapped its that still the code post only when i open the serial monitor in the IDE, only that this time it waits untill the led turns on.... but its possible to change that i don need to open the serial port???... i dont need any status msg on serial monitor, i mean the arduino will never be connected to a computer to run this program.....
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
A local variable that immediately goes out of scope. How useful is that?
Quote
The problem is that you don't use capital letters properly, and don't understand that ONE period or question mark is enough.
There is no reason that you should have to open the serial monitor. If you don't want to, then the Serial methods don't need to be present. Remove them.
Use LEDs to determine where you are getting to in the code.
Logged
Pages: [1] 2 3 4   Go Up
Print
Jump to:
