Topic: help with alarm code (Read 16572 times) previous topic - next topic
AWOL
I think I am too.
Perhaps we could have a code update.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
copachino
Code: [Select]
*msg =& str1;
The type of "*msg" is "char", but you're trying to assign an address to it.
That's why the compiler is upset.
i understand that but, how can assing the variable and not the address??
AWOL
Why don't you post the current code?
"*msg" is what "msg" points to, which is a "char"; you cannot assign an address (another pointer) to a "char"
copachino
this is the code so
Code: [Select]
#include <SPI.h> // needed in Arduino 0019 or later
#include <Ethernet.h>
#include <Twitter.h>
// The includion of EthernetDNS is not needed in Arduino IDE 1.0 or later.
// Please uncomment below in Arduino IDE 0022 or earlier.
//#include <EthernetDNS.h>
int LedState=LOW ;
// Ethernet Shield Settings
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// If you don't specify the IP address, DHCP is used(only in Arduino 1.0 or later).
byte ip[] = { 192, 168, 2, 250 };
// Your Token to Tweet (get it from http://arduino-tweet.appspot.com/)
Twitter twitter("YOUR-TOKEN-HERE");
// Message to post
char* msg[26];
char str1[]="post one";
char str2[]="post two";
char str3[]="post three";
char str4[]="post four";
char str5[]="post five";
char str6[]="post six";
  digitalWrite(2, HIGH);
  attachInterrupt(0, alarm, RISING);
  Ethernet.begin(mac);
  // or you can use DHCP for autoomatic IP address configuration.
  // Ethernet.begin(mac);
  if (ledState == HIGH)
    LedState==LOW;
    Swtich (count)
    { case 1:
    msg =& str1;
    count++;
    break
    case 2:
    msg =& str2;
    count++;
    break
    case 3:
    msg =& str3;
    count++;
    break
    case 4:
    msg =& str4;
    count++;
    break
    case 5:
    msg =& str5;
    count++;
    break
    case 6:
    msg =& str6;
    count=0;
   Serial.println("connecting ...");
  if (twitter.post(*msg)) {
    // Specify &Serial to output received response to Serial.
    // If no output is required, you can just omit the argument, e.g.
    // int status = twitter.wait();
    int status = twitter.wait(&Serial);
    if (status == 200) {
      Serial.println("OK.");
      Serial.print("failed : code ");
      Serial.println(status);
    Serial.println("connection failed.");
void alarm()
  ledState = HIGH;
AWOL
#49
Mar 14, 2013, 10:17 pm Last Edit: Mar 14, 2013, 10:23 pm by AWOL Reason: 1
Code: [Select]
char* msg[26];
What's that?
Code: [Select]
Swtich (count)
Up to a point, people will be willing to help, but if you start just posting garbage that has been pointed out before, they'll get bored and drift away.
copachino
#50
Mar 14, 2013, 10:27 pm Last Edit: Mar 14, 2013, 10:29 pm by copachino Reason: 1
sorry for that i dindt save the last code mods...
Code: [Select]
int count=0;
int LedState=LOW ;
// Message to post
char* msg;
 if (LedState == HIGH)
   LedState==LOW;
   switch (count)
   { case 1:
   msg =& str1;
   count++;
   case 2:
   msg =& str2;
   count++;
   case 3:
   msg =& str3;
   count++;
   case 4:
   msg =& str4;
   count++;
   case 5:
   msg =& str5;
   count++;
   case 6:
   msg =& str6;
   count=0;
void alarm()
 LedState = HIGH;
this is still bad assigned pointer, but i dont know how to assing a char pointer to a char variable, sorry for that
AWOL
copachino
ok that really helps me out,
now there its only one error
Code: [Select]
SimplePost.ino: In function 'void loop()':
SimplePost:84: error: invalid conversion from 'char' to 'const char*'
SimplePost:84: error: initializing argument 1 of 'bool Twitter::post(const char*)'
AWOL
#53
Mar 14, 2013, 10:33 pm Last Edit: Mar 14, 2013, 10:43 pm by AWOL Reason: 1
I don't have the Twitter library (nor do I intend getting it), so that one's up to you.
Enough clues have already been provided (see reply #47)
nickgammon
Code: [Select]
    LedState==LOW;
Time to start reading a basic C tutorial. Don't just thrash around posting whatever comes into your head.
Do some simple programs first. Get the hang of it. Trying to do Twitter in your first code is ridiculous.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
Code: [Select]
    switch (count)
    { case 1:
    msg =& str1;
    count++;
    case 2:
    msg =& str2;
    count++;
    case 3:
    msg =& str3;
    count++;
    case 4:
    msg =& str4;
    count++;
    case 5:
    msg =& str5;
    count++;
    case 6:
    msg =& str6;
    count=0;
And read up on using arrays. Won't you get bored copying and pasting when you end up with 100 messages?
copachino
Code: [Select]
    LedState==LOW;
nick its not my first code, but i did have pratice for long so im kind stck here, that if sentence was proposed by someone on tne debounce thing, so im not used to that i ust leave it that way.....
copachino
so finaly have manage to get it work this its the code
Code: [Select]
int count=0;
int LedState=LOW ;
// Message to post
char* msg;
    LedState=LOW;
    switch (count)
    { case 1:
    msg = str1;
    count++;
    case 2:
    msg = str2;
    count++;
    case 3:
    msg = str3;
    count++;
    case 4:
    msg = str4;
    count++;
    case 5:
    msg = str5;
    count++;
    case 6:
    msg = str6;
    count=0;
  if (twitter.post(msg)) {
void alarm()
  LedState = HIGH;
