Author Topic: Talk MIDI command  (Read 333 times)
I am trying to have a switch trigger notes that will be produced by a wave shield and then have a servo move about 20 degrees..... i have a code and have gotten my music code to work and the switch and servo to work... but I can't seem to get the switch to trigger the music... can anyone help?
 this is my code thus far
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,3);
#include <Servo.h>
 Servo myservo;
byte note = 0;
byte resetMIDI = 4;
int SwitchPin = 0; //switchpin on pin 7
int pos = 70;
int instrument = 0;
int LedPin = 13;
 pinMode(SwitchPin, INPUT);
 pinMode(LedPin, OUTPUT);
 myservo.attach(9);
 Serial.begin(57600);
 mySerial.begin(31250);
 pinMode(resetMIDI,OUTPUT);
 digitalWrite(resetMIDI, LOW);
 delay(100);
 digitalWrite(resetMIDI, HIGH);
 delay(100);
 talkMIDI(0xB0,0x07,120);
 SwitchPin=digitalRead(7); //read pin 7
 myservo.write(pos); //puts servo to position 70 degrees
 delay(5);
 pos=constrain(pos,0,180);
if(SwitchPin==1)
 //Serial.printIn(instrument,"Demo Fancy Sounds");
 talkMIDI(0xB0, 71, 0x79);
 Serial.print("Instrument:");
 //Serial.printIn(instrument, DEC);
 talkMIDI(0xC0, 71, 0);
 noteOn(0, 50, 60);
 delay(200);
 noteOff(0, 50, 60);
 delay(100);
 noteOn(0, 53, 60);
 delay(200);
 noteOff(0, 53, 60);
 delay(100);
 noteOn(0, 52, 60);
 delay(400);
 noteOff(0, 52, 60);
 delay(100);
 noteOn(0, 53, 60);
 delay(400);
 noteOff(0, 53, 60);
 delay(100);
  noteOn(0, 55, 60);
 delay(400);
 noteOff(0, 55, 60);
 delay(200);
  noteOn(0, 58, 60);
 delay(300);
 noteOff(0, 53, 60);
 delay(100);
myservo.write(pos=90);
void noteOn(byte channel, byte note, byte attack_velocity) {
  talkMIDI( (0x90 | channel), note, attack_velocity);
//Send a MIDI note-off message.  Like releasing a piano key
void noteOff(byte channel, byte note, byte release_velocity) {
  talkMIDI( (0x80 | channel), note, release_velocity);
//Plays a MIDI note. Doesn't check to see that cmd is greater than 127, or that data values are less than 127
void talkMIDI(byte cmd, byte data1, byte data2) {
  digitalWrite(LedPin, HIGH);
  mySerial.write(cmd);
  mySerial.write(data1);
Melbourne, Australia
Shannon Member
Lua rocks!
How to use this forum
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Sydney
Big things come in large packages
What do you expect it to do and what is it doing that does not work?
Nice, France
You are not doing anything with data2.
  mySerial.write(data2);
