Topic: How to write and read the EEPROM? (Read 4911 times) previous topic - next topic
danielbcjr
Hi guys,
That´s my first post here so please, apologize me for the dumb question, i was looking for and i didn´t found it.  :smiley-red:
I need to get a number valor from the serial and save it in EEPROM and read it, same  after arduino was restarted.
It´s like in shell script, you know:
number_serial > number.txt
cat number.txt > NUMBER01
Help me plz ^^
JChristensen
Help > Reference > Libraries > EEPROM
danielbcjr
That´s what i need thk you =DDDD  XD
But I´m with doubts in the exemple:
Example
#include <EEPROM.h>
  for (int i = 0; i < 512; i++)
    EEPROM.write(i, i);
I have that comes form serial (IRlib):
  if (irrecv.decode(&results)) {  // IR
    Serial.println(results.value);  // IR
    irrecv.resume(); // IR
    IRr = (results.value * 1);
    Serial.println(IRr );
How can I write IRr valor in the EEPROM?
Like this?
EEPROM.write(i, IRr);
  :smiley-roll-sweat:
danielbcjr
That are the kind of values that I need to storage:
IRn2= 13646
3843765582
IRr= 13646
IRn= 13646
other exemple:
IRn2= 13646
1825097194
IRr= -14870
IRn= 13646
JChristensen
The EEPROM library only deals with bytes. There are several approaches to handle longer data types. For example: (1) Reduced the longer types to byte values using bit shift operations, (2) Use UNION to access the individual bytes in longer data types, (3) Use the eeprom_write_* and eeprom_read_* functions defined in AVR-Libc. Here is an example of the latter. Note there are also functions for double words (32-bit integers), blocks, and bytes.
#include <avr/eeprom.h>      //http://www.nongnu.org/avr-libc/user-manual/group__avr__eeprom.html
#include <EEPROM.h>          //http://arduino.cc/en/Reference/EEPROM
#include <Streaming.h>       //http://arduiniana.org/libraries/streaming/
int myInt1, myInt2;          //note that a 16-bit int is also referred to as a word
float myFloat1, myFloat2;    //floats require 32 bits
void setup(void)
   delay(2000);
   myInt1 = 31416;
   myFloat1 = 3.14159;
   eeprom_write_word( (uint16_t *) 10, myInt1 );    //write a 16-bit int to EEPROM address 10
   eeprom_write_float( (float *) 20, myFloat1 );    //write a float to address 20
   myInt2 = eeprom_read_word( (uint16_t *) 10 );    //read a 16-bit int from address 10
   myFloat2 = eeprom_read_float( (float *) 20 );    //read a float from address 20
   Serial << _DEC(myInt2) << endl;                  //print the values read
   Serial << _FLOAT(myFloat2, 5) << endl;
void loop(void)
jepoy12
We have the same topic I think. It might help.
http://arduino.cc/forum/index.php/topic,152977.0.html
danielbcjr
Jack, how do I get that? #include <avr/eeprom.h>      //http://www.nongnu.org/avr-libc/user-manual/group__avr__eeprom.html
I just found that:
http://download.savannah.gnu.org/releases/avr-libc/
JChristensen
It's already there, just type it in. The code I posted above should compile and run fine. AVR-Libc is part of the Arduino toolchain.
danielbcjr
JChristensen
mixania
Check the Arduino Reference, it explains the steps nice and clear :)
http://arduino.cc/en/Reference/EEPROMRead - Read
http://arduino.cc/en/Reference/EEPROMWrite - Write
