Topic: Problem Firmata on raspberry pi (python) (Read 1 time) previous topic - next topic
Nahuel1990gchu
Python Err Code:
Code: [Select]
Traceback (most recent call last):
  File "/home/pi/Desktop/pyfirmata.py", line 3, in <module>
    import pyfirmata
  File "/home/pi/Desktop/pyfirmata.py", line 7, in <module>
    board = pyfirmata.Arduino(PORT)
AttributeError: 'module' object has no attribute 'Arduino'
Python Code:
Code: [Select]
#!/usr/bin/python
import pyfirmata
PIN = 12
DELAY = 2
PORT = '/dev/ttyACM0'
while 1:
board.digital[PIN].write(1)
board.pass_time(DELAY)
board.digital[PIN].write(0)
Sorry, im speak spanish.
Disculpen el idioma, el problema que tengo es que me tira un error, y no se en que me estoy equivocando, ese es solo un blink pero usando firmata, en el arduino le cargue el StandarFirmata que viene de ejemplo en el ide.
spatula
It seems that your source is called pyfirmata.py, so when you import pyfirmata you are actually importing your own file, not the library. Try using a different name for your file.
