Topic: Amblone (Amblight clone) SoftPWM version issues (Read 884 times) previous topic - next topic
dtokez
Mar 11, 2013, 01:17 am Last Edit: Mar 11, 2013, 01:18 am by dtokez Reason: 1
Hi all, I'm thinking about making a really cheap amblight clone with a 328p hence using softPWM
I can't get the code to compile, I get these errors:
AmbloneSOFT.cpp: In function 'void SetPWMs()':
AmbloneSOFT.pde:-1: error: 'r4_current' was not declared in this scope
AmbloneSOFT.pde:-1: error: 'g4_current' was not declared in this scope
AmbloneSOFT.pde:-1: error: 'b4_current' was not declared in this scope
I'm not sure why because the variables are declared globally I thought?
Here is the code:
#include <SoftPWM.h>
#define C_SF1 0xF1 // Startflag for 1-channel mode (1 RGB channel)
#define C_SF2 0xF2 // Startflag for 2-channel mode (2 RGB channels)
#define C_SF3 0xF3 // Startflag for 3-channel mode (3 RGB channels)
#define C_SF4 0xF4 // Startflag for 4-channel mode (4 RGB channels)
#define C_END 0x33 // End flag
#define C_ESC 0x99 // Escape character
// States for receiving the information, see the flow chart for more info
#define S_WAIT_FOR_SF  0
#define S_RECV_RGB     1
#define S_RECV_RGB_ESC 2
//--------------------------- FUNCTION DECLARATIONS -------------------------
// Receives bytes and returns true if a valid packet was received
boolean PacketReceived();
// Uses the rgb values to set the PWMs
void SetPWMs();
//--------------------------- VARIABLE DECLARATIONS -------------------------
int pulse = 0;
// State we are in: one of the S_* defines
int State = 0;
// The payload of a received message
int Payload[32];
// The amount of RGB values we have received
int ByteCount = 0;
// The character we received
int Recv;
// The amount of RGB channels we are using
int ChannelMode;
// The value for easing (lower is more)
// For more easing adjust the delay in loop()
int easing = 1;
// PWM pins for channel 1
int r1_pin = 2;
int g1_pin = 3;
int b1_pin = 4;
// PWM pins for channel 2
int r2_pin = 5;
int g2_pin = 6;
int b2_pin = 7;
// PWM pins for channel 3
int r3_pin = 8;
int g3_pin = 9;
int b3_pin = 10;
// PWM pins for channel 4
int r4_pin = 11;
int g4_pin = 12;
int b4_pin = 13;
// Current PWM output values (as opposed to target output values)
int r1_current = 0;
int g1_current = 0;
int b1_current = 0;
int r2_current = 0;
int g2_current = 0;
int b2_current = 0;
int r3_current = 0;
int g3_current = 0;
int b3_current = 0;
//----------------------------- IMPLEMENTATIONS -----------------------------
void setup()   {
 // initialize the serial communication
 Serial.begin(256000); // opens serial port, sets data rate to 256000 bps
 TCCR0B = TCCR0B & 0b11111000 | 0x2;
 TCCR1B = TCCR0B & 0b11111000 | 0x2;
 TCCR2B = TCCR0B & 0b11111000 | 0x2;
 State = S_WAIT_FOR_SF;
 SoftPWMBegin();
 if (Serial.available() > 0) {
   PacketReceived();
 SetPWMs();
 delay(10);
boolean PacketReceived() {
 Recv = Serial.read();
 switch (State) {
   case S_WAIT_FOR_SF:
     // =============================== Wait for start flag state
     switch (Recv) {
       case C_SF1:
         // Start flag for 1-channel mode
         ChannelMode = 1;
         State = S_RECV_RGB;
         ByteCount = 0;
         return false;
       case C_SF2:
         // Start flag for 2-channel mode
         ChannelMode = 2;
         State = S_RECV_RGB;
         ByteCount = 0;
         return false;
       case 243://C_SF3:
         // Start flag for 3-channel mode
         ChannelMode = 3;
         State = S_RECV_RGB;
         ByteCount = 0;
         return false;
       case C_SF4:
         // Start flag for 4-channel mode
         ChannelMode = 4;
         State = S_RECV_RGB;
         ByteCount = 0;
         return false;
       default:
         // No action for all other characters
         return false;
     break;
   case S_RECV_RGB:
     // =============================== RGB Data reception state
     switch (Recv) {
       case C_SF1:
         ChannelMode = 1;
         State = S_RECV_RGB;
         ByteCount = 0;
         return false;
       case C_SF2:
         ChannelMode = 2;
         State = S_RECV_RGB;
         ByteCount = 0;
         return false;
       case C_SF3:
         ChannelMode = 3;
         State = S_RECV_RGB;
         ByteCount = 0;
         return false;
       case C_SF4:
         ChannelMode = 4;
         State = S_RECV_RGB;
         ByteCount = 0;
         return false;
       case C_END:
         // End Flag
         // For each channel, we should have received 3 values. If so, we have received a valid packet
         if (ByteCount == ChannelMode * 3) {
           ByteCount = 0;
           return true; // <------------------------ TRUE IS RETURNED
         else {
           // Something's gone wrong: restart
           ByteCount = 0;
           return false;
       case C_ESC:
         // Escape character
         State = S_RECV_RGB_ESC;
         return false;
       default:
         // The character received wasn't a flag, so store it as an RGB value
         Payload[ByteCount] = Recv;
         ByteCount++;
         return false;
     case S_RECV_RGB_ESC:
       // =============================== RGB Escaped data reception state
       // Store the value in the payload, no matter what it is
       ByteCount++;
       State = S_RECV_RGB;
       return false;
 return false;
void SetPWMs() {
 // Channel 1
 r1_current = rgbStep(r1_current, Payload[0]);
 g1_current = rgbStep(g1_current, Payload[1]);
 b1_current = rgbStep(b1_current, Payload[2]);
 SoftPWMSet(r1_pin, r1_current);
 SoftPWMSet(g1_pin, g1_current);
 SoftPWMSet(b1_pin, b1_current);
 // Channel 2
 if (ChannelMode > 1) {
   r2_current = rgbStep(r2_current, Payload[3]);
   g2_current = rgbStep(g2_current, Payload[4]);
   b2_current = rgbStep(b2_current, Payload[5]);
   SoftPWMSet(r2_pin, r2_current);
   SoftPWMSet(g2_pin, g2_current);
   SoftPWMSet(b2_pin, b2_current);
 else {
   // turn the rest to 0 (black)
   SoftPWMSet(r2_pin, 0);
   SoftPWMSet(g2_pin, 0);
   SoftPWMSet(b2_pin, 0);
   SoftPWMSet(r3_pin, 0);
   SoftPWMSet(g3_pin, 0);
   SoftPWMSet(b3_pin, 0);
   SoftPWMSet(r4_pin, 0);
   SoftPWMSet(g4_pin, 0);
   SoftPWMSet(b4_pin, 0);
 // Channel 3
 if (ChannelMode > 2) {
   r3_current = rgbStep(r3_current, Payload[6]);
   g3_current = rgbStep(g3_current, Payload[7]);
   b3_current = rgbStep(b3_current, Payload[8]);
   SoftPWMSet(r3_pin, r3_current);
   SoftPWMSet(g3_pin, g3_current);
   SoftPWMSet(b3_pin, b3_current);
 else {
  // Channel 4
 if (ChannelMode > 3) {
   r4_current = rgbStep(r4_current, Payload[9]);
   g4_current = rgbStep(g4_current, Payload[10]);
   b4_current = rgbStep(b4_current, Payload[11]);
   SoftPWMSet(r4_pin, r4_current);
   SoftPWMSet(g4_pin, g4_current);
   SoftPWMSet(b4_pin, b4_current);
 else {
// rgbStep - the function for easing the colour changes
int rgbStep(int from, int to){
 if(to > from){          // destination colour is greater than current colour
   from += easing;
   if(from > 255){
    from = 255;
   return from;
 else if(to < from){      // current colour is greater than destination colour
   from -= easing;
   if(from < 0){
     from = 0;
   return from;
 else{                    // values are the same...return as submitted
   return from;
Nick Gammon
Well, they aren't defined. These are:
int r1_current = 0;
int g1_current = 0;
int b1_current = 0;
int r2_current = 0;
int g2_current = 0;
int b2_current = 0;
int r3_current = 0;
int g3_current = 0;
int b3_current = 0;
No r4_current though.
More info:
AWOL
A really simple way to find out is to look for the disputed variable, using the IDE's "search" facility.
dtokez
Thanks guys, I took the code direct from the site so I thought maybe it was a problem with the newer IDE.
Thanks again, I'll test the code tonight :)
AWOL
Which site?
dtokez
Which site?
http://amblone.com/
I'm using the standard software on a 2560 and running 12 channels but seems a bit over kill to have a mega sat there running it so I want to build a cheap version now so I can have my Mega back :)
