Topic: Control Livolo switches / Livolo switch library (Read 170666 times) previous topic - next topic
winnaing
Hi spch
Thanks for your reply. I follow your advice as follow:
1) I changed ID for a few combinations, not successful.
2) Yes, other third party remote can control the Livolo and I try to decode it, also not successful.
Maybe the way I did is not correct. By the way, what is interleave?   :smiley-roll:
Regards
spch
#16
Oct 21, 2013, 07:42 pm Last Edit: Oct 25, 2013, 07:19 am by spch Reason: 1
Winnaing,
I was pretty sure that I could say "interleaving" to describe a rule of high pulse following low pulse and vice versa. Sorry for bad English, if I got that wrong.
Here is more "user friendly" code. No more strange arrays full of strange numbers ;) It requires only two values: Remote ID and a keycode of button to "press".
There are three predefined working Remote IDs (and it is possible to use many more as long as Remote IDs are 16 bit), and 11 predefined buttons (and, maybe, it is possible to use any other as long as keycodes are 7 bit).
Bottom line: it should work. If it doesn't, please tell me what went wrong and I'll try to figure out how to fix it.
Code: [Select]
#define  txPin  8 // pin connected to RF transmitter (pin 8)
byte i; // just a counter
byte pulse; // counter for command repeat
boolean high = true; // pulse "sign"
// keycodes #1: 0, #2: 96, #3: 120, #4: 24, #5: 80, #6: 48, #7: 108, #8: 12, #9: 72; #10: 40, #OFF: 106
// real remote IDs: 6400; 19303
// tested "virtual" remote ID: 8500, other IDs could work too, as long as they do not exceed 16 bit
// known issue: not all 16 bit remote ID are valid
// have not tested other buttons, but as there is dimmer control, some keycodes could be strictly system
// use: sendButton(remoteID, keycode);
// see void loop for an example of use
sendButton(6400, 120); // blink button #3 every 3 seconds using remote with remoteID #6400
delay(3000);
void sendButton(unsigned int remoteID, byte keycode) {
  for (pulse= 0; pulse <= 180; pulse = pulse+1) { // how many times to transmit a command
  sendPulse(1); // Start
  high = true; // first pulse is always high
  for (i = 16; i>0; i--) { // transmit remoteID
    byte txPulse=bitRead(remoteID, i-1); // read bits from remote ID
    selectPulse(txPulse);
  for (i = 7; i>0; i--) { // transmit keycode
    byte txPulse=bitRead(keycode, i-1); // read bits from keycode
   digitalWrite(txPin, LOW);
// build transmit sequence so that every high pulse is followed by low and vice versa
void selectPulse(byte inBit) {
      switch (inBit) {
      case 0:
       for (byte ii=1; ii<3; ii++) {
        if (high == true) {   // if current pulse should be high, send High Zero
          sendPulse(2);
        } else {              // else send Low Zero
                sendPulse(4);
        high=!high; // invert next pulse
      case 1:                // if current pulse should be high, send High One
        if (high == true) {
          sendPulse(3);
        } else {             // else send Low One
                sendPulse(5);
// transmit pulses
// slightly corrected pulse length, use old (commented out) values if these not working for you
void sendPulse(byte txPulse) {
  switch(txPulse) { // transmit pulse
   case 1: // Start
   digitalWrite(txPin, HIGH);
   delayMicroseconds(500); // 550
   case 2: // "High Zero"
   delayMicroseconds(100); // 110
   case 3: // "High One"
   delayMicroseconds(300); // 303
   case 4: // "Low Zero"
   case 5: // "Low One"
   delayMicroseconds(300); // 290
winnaing
Hi spch
It is wonderful. All ID key are working. Thank you.  :)
I try to 'decode' your ID key but still don't understand and no luck.
Anyway I try to digest your advice and try to look for other IDs. For the time being, 30 codes are enough for me.
Have you try Koti light switch? see http://www.aliexpress.com/store/529450
The good thing about these switches is that they are bicommunication; ie switch send back the feedback signal.
So we know exactly if switch on or off. Whereas Livolo is not.
Again, I have checked with supplier. They said their code is propitiatory and do not work with 3rd party RC.
I don't have the talent to decode them. So I did not buy.
Anybody ever decode them successfully?
Regards
spch
Hello Winnaing,
Glad to know the code is working. Koti switches could use proprietary protocol (Livolo, by the way, does use its own proprietary protocol too) or they can use Z-Wave protocol as store name suggests. In the latter case you don't need to decode anything as there are Z-wave modules for Arduino.
But if Koti switches use fixed codes just like Livolo, they can be decoded as well.
baustromverteiler
Thanks for decoding the Livolo protocol and your sketch, I already got it to work with my Livolo switches! I was wondering if there is any way to use the Livolo dimmers with your code?
Regards, Max
spch
Max,
I guess it is highly probable. At least, manual for VL-RMT-01 remote that I have says that buttons 7 (on), 9 (off), "+" (more light) and "-" (less light) can be used to control dimmer switch.
I don't have dimmer switches, that is why I have not scanned "+" and "-" buttons yet. I'm planning to do that this or next week, and after that you will be able to test dimmer feature.
baustromverteiler
thanks for your really fast reply  -  I'm really looking forward to test the dimmer feature :) keep up the great work!
winnaing
Hi spch
I still cannot find new ID yet. For example, i use 6500 for ID which is 0001 1001 0110 0100. I though it follow your rule.
But it did not work either. Which pulse is not following your rule?
I understand that KOTI use FSK protocol. Still can decode?
Regards
spch
#23
Oct 23, 2013, 07:31 pm Last Edit: Oct 24, 2013, 09:17 am by spch Reason: 1
baustromverteiler,
I've just recorded what I believe are dimmer buttons. I have to sets of dimmer buttons  (+/-) on the remote, and they have different keycodes. So here are both sets:
1) "+": 92  ; "-": 116
2) "+": 126; "-": 36
It's in the manual that I've found on the net that dimmer should be "paired" with buttons 7 and 9. Regretfully there is nothing on pairing and I don't have dimmer switch, so I can not test it.
winnaing,
It seems, you are right. Not all remote IDs are working. Sorry, I can not find the reason - it is really beyond my understanding. Maybe, I missed something or there is a bug in the code.
So there is a hit or miss approach: try different remote IDs to find ones that work. For example, I found that 7400, 6550, 10550 can be used with Livolo switches.
As to FSK, it is not really a protocol - it is method of modulation used to transmit data over RF. Basically it can be easily demodulated using FSK receiver (the same way as I demodulated Livolo's signal using ASK receiver). And there are two ways to use received data:
1) Try to "copy" code sequence without trying to understand underlying protocol;
2) Try to decode and use original protocol.
First will do if it is about fixed codes. Second is good to deal with fixed and dynamic codes, although to me dynamic codes are really hard to hack.
Regards,
Sergey.
baustromverteiler
Thanks for the keycodes - I'll let you know how it worked out
winnaing
Hi spch
Thanks for new IDs.
As for FSK ; are you saying that it works with fsk receiver and will not work with ask receiver?
Then where can I find fsk receiver? It is like all arduino store sell ask receiver.
Regards
spch
Hi winnaing,
Of course, ASK receiver won't be able to receive FSK transmission. Here is a simple FSK receiver:
http://www.ebay.com/itm/Very-Good-FSK-Replace-ASK-Transparent-Wireless-Data-Receier-RX-Module-433MHZ-/271302707346?pt=LH_DefaultDomain_0&hash=item3f2ae6c892
and here are both FSK receiver and transmitter:
http://www.ebay.com/itm/FSK-Directly-Replace-ASK-200-300-Meters-Transparent-Wireless-Data-433MHZ-Modules-/261050654636?pt=Vintage_Electronics_R2&hash=item3cc7d4dfac
spch
Hi eltin,
These should be just fine. My transmitter looks exactly the same.
spch
#29
Oct 25, 2013, 04:47 pm Last Edit: Jan 03, 2015, 06:36 pm by spch Reason: 1
Hi folks,
It is now a Livolo switch control library.
Just unzip Livolo folder under your Arduino/libraries folder, restart Arduino IDE if it was open at the moment, connect Arduino board with ASK RF transmitter to PC, upload test sketch and put your Livolo switch into learning mode.
If everything goes right, your light will turn on and off every 3 seconds. See readme.txt for more info.
Default TX pin is 8, but you can use any digital pin you like.
Enjoy!
