Loading...
Pages: [1]   Go Down
Author Topic: What PCB manufacturers beat OSH Park on DRU minimums?  (Read 316 times)
Samplefinger
Offline Offline
God Member
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
View Profile
OSH's DRU minimums are 6 mil trace width / 6 mil spacing / 13 mil drill size / 7 mil annular ring.  In routing a 100 pin BGA part I have found that to meet these rules on a 2 layer board I have to make my pads 12 mils.  The default for this part is 16 mils.  So this gives me pause and I ran it by the guy who supports DipTrace over at their forum and he thinks it is not a good idea either.  The fact is, with these minimums, there doesn't seem to be any way to route the innermost pins on a 2 layer board without getting the pads down to 12 mils.
Are there PCB manufacturers that have smaller DRUs than the ones I stated above that OSH Park uses?  This was the fanout I was able to get with OSH's minimums plus making the pads 12 mils.  It is the best I can do and the autorouter does worse.
Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Itead goes smaller. I normally use 12mil drills with them.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
PCB capabilities for IteadStudio
(need conversions from mm to mil to mm:
10 mil = 0.254mm
.15mm = 5.9mil, call it 6 mil)
Layers
 1 - 4
Material
 FR-4
Board Dimension (max)
 500mm X1100mm
Board Dimension (min)
 10mm X10mm
Outline Dimension Accuracy
 ± 0.2mm >> 7.9mil
Board Thickness
 0.40mm--2.0mm >> 15.7mil to 78.7mil
Board Thickness Tolerance
 ± 10%
Dielectric Separation thickness
 0.075mm--5.00mm >> 3 mil to 197 mil
Conductor Width (min)
 0.15mm( Recommend>8mil ) >> 6mil
Conductor Space (min)
 0.15mm( Recommend>8mil) >> 6 mil
Outer Conductor thickness
 35um
Inner Conductor thickness
 17um--100um
Copper to Edge
 0.25mm,0.5mm >>10 mil, 20 mil  (why 2 numbers?)
Plated Component,Plated via Diameter(Mechanical)
 0.3mm--6.30mm >>12mil to 248 mil
Plated Hole Diameter Tolerance(Mechanical)
 0.08mm >> 3 mil
Unplated Hole Diameter Tolerance
 0.05mm >> 2 mil
Hole Space(min)
 0.25mm >> 10 mil
Hole to Edge
 0.4mm  >> 16 mil
Annular Ring(min)
 0.15mm >> 6 mil
Aspect Ratio
 8:01
Solder Resist Type
 Photosensitive ink
Solder Resist Color
 Black ,Green, White, Blue ,Yellow
Solder Resist Clearance
 0.1mm >>  4 mil
Solder Resist Coverage
 0.1mm >> 4 mil
Plug Hole Diameter
 0.25mm--0.60mm >>10 mil to 24 mil
Selective Finish
 HASL, ENIG
Logged
Colorado
Offline Offline
Edison Member
Reviving dead brain cells with Arduinos.
View Profile
I can confirm iTead's minimums as well.  I have done several 6mil traces and 10mil drills boards through them.
Logged
Samplefinger
Offline Offline
God Member
View Profile
I'm not seeing how 6 mil traces beat 6 mil traces but 10 mil drills certainly beat 13 mil drills.
My only concern is seeing this:
http://hackaday.com/2012/09/11/bed-of-nails-and-accuracy-in-pcb-manufacturing/
Do you think this was an outlier?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I see 64 pads around the perimeter. Where do the other 36 go? Pads on the bottom layer?
Looks like their might be a hint of another layer, kinda dark on my moniter, like dark brown on black.
Logged
Samplefinger
Offline Offline
God Member
View Profile
Any comments about pad size?   In DipTrace the default pad size for the Atmel 2560 CBGA is 16 mils.  Is 12 mils a show stopper?  How is that determined, manufacturer specified or CAD vendor specified or somethign else?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Pad size for the balls should come from the spec sheet of the part you are using.
Pad size around the outside is your call for mating to traces for the rest of the board. Go as wide as you can while leaving 8-10mil clearance in between to meet DRU rules for trace clearance/seperation distance.
Logged
UK
Offline Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
View Profile
WWW
From the datasheet for the ATmega640/1280/1281/2560/2561
In the details for the 100C1 CBGA:
Ball diameter: Min: 0.35mm (13.78 mil) Typ: 0.40mm (15.75 mil) Max: 0.45mm (17.72 mil)
It doesn't actually give a recommended landing pattern as such, unfortunately, like a lot of other data sheets do, so it's pretty much guesswork what the size should be.
16 mil is a good size as it's pretty much the "typical" ball size.  14 mil would be acceptable I guess at a pinch.
I wouldn't go below 14 mil - that's just asking for trouble.
Logged
Samplefinger
Offline Offline
God Member
View Profile
16 mil is exactly what DipTrace provides on that pattern so they agree with you.  I guess I will try again with 14 mil pads and see what I can get it to do.
« Last Edit: March 14, 2013, 04:14:20 pm by JoeN » Logged
Pages: [1]   Go Up
Print
Jump to:
