Topic: Send/Recive between 2 arduinos (Read 2459 times) previous topic - next topic
MrMr
Hi
I am trying to send and recive serial communication with the help from 2 max485 and 2 arduinos.
There seems to be something wrong with the code (suprice?  ;)), it doenst get every bit that i am sending. I am sending a "1" .. wait... then sending "0" and so on.
The LED on the reciving board turns on, and off. But doenst do anything for 2-3-4 pulses and then keeps on going like before - totaly random.
they are both powered on by USB from the same PC.
Arduino 1 - Sending unit
void setup(){
  Serial.begin(9600); //opens serial port, sets data rate to 9600 bps
  pinMode(2, OUTPUT);
  digitalWrite(2, HIGH); // Set pin2 HIGH
  Serial.write(1); // send a byte with the value 1
  delay(2000);  // Wait 2sec
  Serial.write(0); // send a byte with the value 0
Arduino 2 - Reciving unit
int incomingByte = 0;   // for incoming serial data
        Serial.begin(9600);     // opens serial port, sets data rate to 9600 bps
        pinMode(13, OUTPUT);
        // send data only when you receive data:
        if (Serial.available() > 0) {
                // read the incoming byte:
                incomingByte = Serial.read();
                // turn on/off LED
         if (incomingByte > 0) {
                 digitalWrite(13, HIGH);
                  digitalWrite(13, LOW);
Any suggestions i have done wrong? Seems pretty basic, but cant find the mistake.
HazardsMind
Why not try to debug it with the serial monitor? You should see what you are getting, and adjust your code from there.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
MrMr
#2
Mar 11, 2013, 02:46 pm Last Edit: Mar 11, 2013, 02:59 pm by MrMr Reason: 1
Thanks for the quick answer.
I am getting some thing like "110101001" so somehow it doenst recive every time i send a 1 or 0.
The LED changes when it is 1 and 0. So no problem there. But the information recived is not correct with the information send.
**Update**
this is the exact serial monitor "010101001010110101001010010101" - The time between i get each number is difrent. Sometimes i get 0101 as i should. Other times there are a bigger delay.
CrossRoads
On the receive side:
I think you might have data type mismatches, so that you think you sending
0x00 or B00000000 but are actually sending '0' which is 0x30, B00110000
and 0x01 or B00000001  vs '1', 0x31 B00110001
See asciitable.com
If so, this might solve it:
if (incomingByte == '0') {
and
if (incomingByte == '1') {
or perhaps
switch(incomingByte){
case '0':
//code
break;
case '1':
// code
break;
} // end switch
PeterH
The code looks reasonable so I would suspect there's a problem with the serial communication mechanism.
You say you're using a pair of max485 transceivers. How have you connected them to each other and to the Arduinos? Did you remember to connect the grounds?
MrMr
#5
Mar 12, 2013, 08:19 am Last Edit: Mar 12, 2013, 08:24 am by MrMr Reason: 1
I just hooked it up again and now i get these numbers "4948494849484949" in the serial monitor. Now i am lost.
Crossroads: Thanks for the suggestions. Neither of the solutions did solve the problem.
PeterH: very bad drawings but hope you understand. https://www.dropbox.com/s/6h4j220xxasc1tr/Arduino-S-R.JPG
DI to TX(1) and RO to RX(0) on both sender and reciver.
*Update*
Forgot about the resistors. I got a resistor of 150ohm between A and B on both max485. Got a 560 resistor from the one end of A to GND and B to 5V. Altso 560 ohm.
nickgammon
Not when I just tested it. Is your first post still the current code?
nickgammon
48 is hex 0x30 which is '0'
49 is hex 0x31 which is '1'
In ASCII that is. So if you have altered your sketch in some way those numbers are perfectly reasonable.
MrMr
No. I tried that "case '1' " code as suggested. That was when i got these in weird numbers in the serial monitor. Must be the cause, because i got "10101100101" with the code from first post.
nickgammon
Are you dropping the enable bit immediately after sending?
Maybe read this: http://www.gammon.com.au/forum/?id=11428
Scroll down to "Flushing the output".
nickgammon
The code in your first post (Arduino 1 - Sending unit) does not generate those numbers.
Can you post your current sending code please?
MrMr
The code is exactly the same as in the first post. Thats why i am confused. I will upload the code again and the problem should be gone, cant see why this suddently happens when i am sending 1 and 0s.
At the moment i have the pin2 (my enable) on HIGH always. Maybe this is the problem, i will read your post and see if it explains the problems.
Cant say thanks to many times. So thanks again.
MrMr
I didnt see this message, sorry. The reciving part had the case 1 case 2 code. That was the diffrence.
MrMr
#13
Mar 13, 2013, 10:37 am Last Edit: Mar 13, 2013, 10:39 am by MrMr Reason: 1
I think i solved the problem.
       if (Serial.available() > 0) [b]{[/b]
               // turn on/off LED
moved the bracket down and it all worked. 1.0.1.0.1.0.1.0
- thanks for the help guys. It is very apriciated!
