Topic: Help with OpenOCD JTAG debugging (Read 2840 times) previous topic - next topic
rdiez
Hi all:
I am trying to set up a stable GDB debugging environment over JTAG with the Arduino Due, but I'm having no luck. I am confused by the error messages, and the documentation does really not help. I have found more information on the Web, but I haven't managed to make it work yet.
Has anybody got JTAG working yet? Could you share your configuration files?
I am using a Bus Pirate as the JTAG adapter, the configuration file is:
interface buspirate
buspirate_port /dev/buspirate
buspirate_speed normal ;# or fast
# voltage regulator Enabled = 1 Disabled = 0
#buspirate_vreg 0
# pin mode normal or open-drain
#buspirate_mode normal
# pullup state Enabled = 1 Disabled = 0
#buspirate_pullup 0
# this depends on the cable, you are safe with this option
reset_config srst_only
adapter_khz 10
I am not sure what settings are the right ones above, but it seems to detect the device OK.
I am on Ubuntu 12.04, and I am using the latest git version of OpenOCD (0.7.0-dev), with a standard configuration file for the Atmel chip on the Arduino Due: -f target/at91sam3XXX.cfg
By the way, I don't know whether these OpenOCD commands are necessary, or whether they should come before or after the at91sam3XXX.cfg file:
  gdb_memory_map enable
  gdb_flash_program enable
I tried with and without them, and there seems to be no difference.
I am using the toolchain that comes with the Arduino environment, version 1.5.2.
When I start OpenOCD, I get these messages:
Open On-Chip Debugger 0.7.0-dev-00079-g08ddb19-dirty (2013-02-26-10:39)
Licensed under GNU GPL v2
For bug reports, read
         http://openocd.sourceforge.net/doc/doxygen/bugs.html
Warn : Adapter driver 'buspirate' did not declare which transports it allows; assuming legacy JTAG-only
Info : only one transport option; autoselect 'jtag'
srst_only separate srst_gates_jtag srst_open_drain
adapter speed: 10 kHz
adapter speed: 500 kHz
adapter_nsrst_delay: 100
jtag_ntrst_delay: 100
cortex_m3 reset_config sysresetreq
Info : Buspirate Interface ready!
Info : Want to set speed to 500kHz, but not implemented yet
Error: Translation from jtag_speed to khz not implemented
Info : adapter-specific clock speed value 500
Info : JTAG tap: sam3.cpu tap/device found: 0x4ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x4)
Info : sam3.cpu: hardware has 6 breakpoints, 4 watchpoints
Then, when I connect with GDB, this is what I have tried so far:
target remote :3333
I get this on OpenOCD's console:
Info : accepting 'gdb' connection from 3333
Warn : acknowledgment received, but no packet pending
undefined debug reason 6 - target needs reset
The target does not stop. I have another embedded target from another type, and it does stop when you connect with GDB.
Then I tried this on GDB's console:
set remotetimeout 1000
target remote :3333
monitor halt
If I enter "monitor reset halt", instead of "monitor halt", I get this error:
  in procedure 'reset'
  Info : Halt timed out, wake up GDB.
  Error: timed out while waiting for target halted
  TARGET: sam3.cpu - Not halted
With "monitor halt", I get a reassuring message:
target state: halted
target halted due to debug-request, current mode: Thread
xPSR: 0x81000000 pc: 0x000805d4 msp: 0x20087fe8
I can now issue a "monitor reset halt", and the output looks like this:
xPSR: 0x81000000 pc: 0x0008036c msp: 0x20087fe8
No matter what I do, I haven't managed to reset the CPU and make it stop at the reset vector address (0x00000004). This is important in order to start debugging from scratch. Otherwise, the CPU has already executed a bit of code before you try to debug.
If I enter the 'load' command, this is what I get:
  Loading section .text, size 0x3a80 lma 0x80000
  Loading section .relocate, size 0x9c lma 0x83a80
  Start address 0x80124, load size 15132
  Transfer rate: 2 KB/sec, 7566 bytes/write.
This is interesting, as I am using linker script file "hardware/arduino/sam/variants/arduino_due_x/linker_scripts/gcc/flash.ld" which comes with Arduino 1.5.2, and that specifies the flash address as  0x00080000, which matches the .text section above. However, it looks like the flash memory is not been written to, as the old program ('sketch') transferred with the Arduino environment remains there.
Is there a way to verify that the program data bytes has been properly written to flash?
Can anybody help with any of the questions above?
Many thanks in advance,
  rdiez
