Topic: Nuovi sviluppi IDE 1.8.x (Read 388988 times) previous topic - next topic
PaoloP
Mar 11, 2013, 04:06 pm Last Edit: Aug 23, 2018, 09:21 pm by PaoloP
23/08/2018: Disponibile la versione 1.8.6
--> http://arduino.cc/en/Main/Software
Quote
ARDUINO 1.8.6 2018.08.23
[ide]
* Updated arduino-builder to 1.4.0:
  - parallel build (improve compile speed)
  - better reuse of already compiled files
  - Windows: fixed build for sketch stored under OneDrive cloud folders
* Added translations for library types. Thanks @ReAlUA
* Added scroller in programmers menu.
* Added "accelerator" in scrollable menu, press "a" key while scrolling
* Keep "Board Manager" menu item always as first in the menu
* "Manage Libraries" is now also in the "Tools" menu. Thanks @feikname
* Compiler errors now have both column and line
* Serial monitor how has "Show Timestamp" option. Thanks @MichalSy
* Improved DPI detection for hi-resolution montior on Linux
* Added copy/paste contextual menu in Find/Replace text fields
* Fixed long IDE startup time when some virtual/not-connected network interfaces are present
* Fixed inconsistent line-endings when saving files on Windows
* mdns: Make board disappear via TTL instead of reachability. Thanks @kurtgo
* Library Manager: display install/remove buttons with mouse on-hover instead of mouse click
* Board Manager: fixed some rare case with corrupted index download
* Windows: removed some debug output when running the IDE from command line
* Support selectable user-defined themes. User's theme are zip files inside the sketchbook "theme" folder
* Library Manager: library search now search also for headers (.h) declared by the library in library.properties
* Added "--version" to the CLI. Thanks @yohsuke
* Fixed Serial Plotter/Monitor permanently disabled if Plotter fails to open
* Fixed window title that sometimes is not updated on "Save as...". Thanks @JxJxJxMxNxS
* Fixed keybindings for Increase/Decrease font size
* Improved accessibility in the Preferences dialog. Thanks @coreyknapp
[core]
* AVR: Set Optiboot as default bootloader for Nano. This is the bootloader installed on new
       Arduino Nano boards. If you have a Nano with the old bootloader you must select
       Tools > Processor > ATmega328P (Old Bootloader) to upload.
* AVR core has been moved to its own repository: https://github.com/arduino/ArduinoCore-avr
* Updated toolchain to gcc 5.4.0
[wifi101-firmware]
* SECURITY FIX: Released fix for WPA2 KRACK vulnerability (latest WINC1500 firmware 19.5.2).
02/10/2017: Disponibile la versione 1.8.5
Quote
ARDUINO 1.8.5 2017.09.29
(bugfix service release)
[ide]
* Added workaround for menu visibility bug in MacOSX 10.13 beta. Thanks @puybaret
* Fixed bug for negative-font-size.
* New/Rename tabs now allows names starting with a number.
23/08/2017: Disponibile la versione 1.8.4
Quote
ARDUINO 1.8.4 2017.08.23
[ide]
* IDE Toolbar can now go full width on 4K display.
* Environment variable LIBRARY_INDEX_URL is now correctly parsed (LIBRARY_INDEX_URL_GZ can also be optinally specified). Thanks @xardael
* Added per-board generic option in config file boards.txt for disabling control of dtr+rts. Thanks @d-a-v
* CLI: fixed missing "runtime.platform.path" when running without the `--board` option
* Linux: fixed desktop icon not launching the IDE in certain Window Managers (thanks @herrold)
* Allow setting low values for console size (correctly applies console.lines=x in preferences.txt)
* Make Preference window fit 600px height displays
* Fix error when renaming an unsaved, newly added file. Thanks @matthijskooijman
* Added the ability to increase/decrease font size via keyboard + mouse shortcuts (Ctrl + MouseWheel)
* Sketch names starting with a digit are now allowed
* Serial monitor is opened on a default position if the multi-monitor setup change (this should fix cases
  when the serial monitor is opened outside of the visibile space)
[libraries]
* Fixed wrong folder name for "Adafruit Circuit Playground" library, now it can be updated cleanly.
* Fixed wrong include for "RobotIRRemote", now it should not interfere anymore with the real IRRemote.
31/05/2017: Disponibile la versione 1.8.3
Quote
ARDUINO 1.8.3 2017.05.31
[ide]
* Fixed RESOURCE_NAME in install.sh script
* Serial Monitor: added "Clear output" button. Thanks @MichaelSy
* added options in preferences.txt for: custom title, comment/uncomment shortcut, always show file extensions. Thanks @MichaelSy
* added options in preferences.txt to enable/disable typing assistance (auto close brace, auto indent)
* Enabling "Use external editor" option now requires to save all sketches.
[core]
* AVR: added availableForWrite() method in generic Stream class. Thanks @eric-wieser
* AVR: moved flush() method up in the class hierarchy from Stream to Print class. Thanks @matthijskooijman
[other]
* Update Wifi101 Firmware Updater plugin
22/03/2017: Disponibile la versione 1.8.2
Quote
ARDUINO 1.8.2 2017.03.22
[ide]
* Fix command line: works again with relative paths (regression)
* Fix command line: "--save-prefs" works again (regression)
* AVR toolchain has been updated with a tentative fix for the ld-returned-5-exit-status bug
* Update arduino-builder to 1.3.25
  - avoid name clashing for libraries
  - cache core archives to speedup compilation consistently
* Allow BoardManager to fetch FreeBSD tools (thanks @kevans91)
* Serial monitor: the input string box is automatically focused when window is selected
* Serial monitor: now can not be opened during upload
* Serial monitor: now properly decodes UTF8 characters (thanks @aknrdureegaesr)
* Serial monitor: added 500k, 1M and 2M baudrates (thanks @dsstutts)
* Updated RSyntaxTextArea to 2.6.1 (textarea component)
* Updated jmdsn (mDNS discovery)
* Allow plugins to attach a listener to compile progress (thanks @tomneutens)
[core]
* Add Atmel-ICE and JTAGICE3 programmers for AVR chips (thanks @matthijskooijman)
* AVR: Set unused bits of extended fuse to 1, should remove some avrdude warning during burn bootloader (thanks @descampsa)
* AVR: USB: send ZLP when needed (allows full 64 bytes packets)
* AVR: USB: use IAD descriptors instead than Generic (thanks @cuitoldfish)
[other]
* SAM platform source code has been moved to its own repository (https://github.com/arduino/ArduinoCore-sam) - all PRs and issues have been moved as well
09/01/2017: Disponibile la versione 1.8.1
Quote
ARDUINO 1.8.1 - 2017.01.09
[ide]
* Fixed font rendering not anti-aliased on Windows (regression)
* Increased number of colors on serial plotter to 8, thanks @cousteaulecommandant
[libraries]
* Fixed regression in SD library. Thanks @greiman
23/12/2016: Disponibile la versione 1.8.0
Quote
ARDUINO 1.8.0 - 2016.12.20
[ide]
* Linux: running in command line mode doesn't require an X11 display anymore
* "Save as" now clears the "modified" status
* builder: Paths with strange UTF8 chars are now correctly handled
* builder: .hpp and .hh file extensions are now considered valid sketch extension
* builder: core.a is not rebuild if not needed (improve build time in particular for big projects)
* Fixed swapped actions "Copy for Forum" and "Copy as HTML"
* Linux/osx: If an editor tab is a symbolic link it is no more replaced with a real file when saving (see #5478)
* Increased the upload timeout to 5 minutes (it was 2 min, but it may be not sufficient when uploading via UART a big sketch)
[core]
* Added Arduino.org boards
* Added Adafruit Circuit Playground board
* Added "-g" option to linker to keep debug information in the .elf file (see #5539)
* avrdude: Added fake configuration for EFUSE on atmega8 part. This solves a long standing issue with "Burn bootloader".
  Thanks @rigelinorion, @awatterott
ChangeLog completo --> https://github.com/arduino/Arduino/blob/master/build/shared/revisions.txt
leo72
Io compilo dai repo ogni settimana, ho sempre la versione più aggiornata  :P
PaoloP
Aggiungo che, secondo me, le versione precedenti alla 1.0 dovrebbero essere considerate ormai deprecate.  :smiley-red:
leo72
Le versioni antecedenti alla 1.0.1, tra quelle deprecate ci metterei anche la 1.0 per i noti problemi relativi al bug dello sketch ArduinoISP.
menniti
NON SIA MAIIIIII!!! Ogni volta che qualcosa non va, cambio percorso e tiro fuori dalla sua cartella avvolta nel velluto, la mia fiera 0022, compagna di tante avventure e mai un tradimento :D
La 1.0 NON ha mai avuto il piacere di incontrare i miei computer  ]:D ne sono stato sempre fieramente alla larga.
Invece questo aggiornamento lo farò appena ho un minuto (circa Ferragosto, credo :smiley-sad-blue:)
Manuale "Arduino e le tecniche di programmazione dei microcontrollori ATMEL"
http://www.michelemenniti.it/manuale_di_programmazione.html
http://www.michelemenniti.it/offerta.html
Articoli ElettronicaIN
http://www.michelemenniti.it/elettronica_in.html
leo72
Neanch'io ho mai messo la 1.0, a dire il vero neanche la 0022, e sono passato direttamente alla 1.0.1.
Ma da quando ci fu quel problema con il menu a tendina di selezione della velocità seriale dell'IDE compilo sempre dai sorgenti.
astrobeed
Problema presente solo se usi la versione localizzata invece di quella in Inglese, mi pare sia ancora presente anche sulla 1.0.3, non ne sono sicuro perché io uso solo la versione in Inglese e mai quella localizzata in Italiano.
Scientia potentia est
leo72
E' stato risolto, non mi ricordo se nella 1.0.2 o nella 1.0.3
lestofante
1.0.2, l'ho scaricata apposta :-)
Guida per principianti http://playground.arduino.cc/Italiano/newbie
Unoffical Telegram group https://t.me/genuino
Jazzo
Fondamentale questo:
* Fixed memory leak when calling Ethernet.begin() multiple times
lestofante
uhmm in teoria la begin la dovresti chiamare una volta, e poi il resto sono server.available()..
QUETSO!  -----> Fixed malloc bug  <------ è il vero bug fix della versione
leo72
No, sei fuori strada  ;)
La 1.0.4 è stata rilasciata per introdurre la libreria GSM per il nuovo shield dell'Arduino di cui si parla qui  XD
astrobeed
Opinione personale, usare la malloc su un sistemino basato su una modesta mcu 8 bit con 2k di ram è come pestarsi le dita con una mazza da 5 kg  :smiley-mr-green:
PaoloP
Tra l'altro, secondo una roadmap apparsa tempo fa sulla mailing list, questa dovrebbe essere l'ultima versione della serie 1.0.x
Le prossima sarà la versione stabile della 1.5.x che ingloberà (com'è già adesso) anche il core di Arduino, oltre che quello della DUE.
Inoltre stanno sviluppando un repository unificato per le librerie di terze parti.
lestofante
ma se non erro la malloc viene usata molto spesso nelle librerie arduino, in primis la String, che usiamo praticamente tutti.
