Topic: Help debugging client connected ethernet shield [SOLVED] (Read 2045 times) previous topic - next topic
blastboot
Mar 11, 2013, 05:35 pm Last Edit: Mar 12, 2013, 03:33 pm by blastboot Reason: 1
Hello, need your help again debugging an issue that is driving me crazy...
I can't get the code to pass the IF (client) statement when there is a client connected to the ip adress of ethernet shield. i've done a lot of debugging but i can't see why... could you please look at my code and tell me what is wrong?
#include <SPI.h>
#include <SdFatUtil.h>
#include <Ethernet.h>
#include <VirtualWire.h>
//DECLARAÇÃO DOS PINOS
const byte ledInfo = 2;
const byte ledRececao = 3;
const byte pinoRececao = 8;
const byte BUFSIZ = 128;
//DECLARAÇÃO DAS VARIÁVEIS GLOBAIS
char mensagem[5];
unsigned int dadosAgua = 0;
float dadosBat = 0; //confirmar se é melhor float ou int
float percentagem = 0;
unsigned long litros = 0;
unsigned int nrLeitura = 1;
boolean Log = false;
//CONFIGURAÇÃO DO ETHERNET SHIELD
byte mac[] = {0x80, 0xA2, 0xDA, 0x00, 0xEA, 0x8C};
IPAddress ip = (196, 168, 0, 3);
char ficheiroIndex[] = "index.htm";
char ficheiroLog[] = "&logg.txt";
char ficheiroTanque[] = "tanque.jpg";
char ficheiroBorder[] = "border.jpg";
char ficheiroRodape[] = "rodape.jpg";
char ficheiroIframe[] = "iframe.htm";
char ficheiro2Iframe[] = "2iframe.htm";
char* ficheiroLer = '\0';
EthernetServer server(80);
EthernetClient client;
//PROGRAMAÇÃO DO CARTÃO SD
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
SdFile LOGfile;
//ARMAZENA SEQUÊNCIAS DE ERRO NA MEMÓRIA FLASH PARA ECONOMIZAR RAM
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
 PgmPrint("Erro: ");
 SerialPrintln_P(str);
 if (card.errorCode()) {
   PgmPrint("Erro cartao SD: ");
   Serial.print(card.errorCode(), HEX);
   Serial.print(',');
   Serial.println(card.errorData(), HEX);
 digitalWrite(ledInfo, HIGH);
 while(1);
 delay(100);
 pinMode(ledInfo, OUTPUT);
 pinMode(ledRececao, OUTPUT);
 pinMode(10, OUTPUT);
 //LIGA E DESLIGA OS 2 LEDS PARA INDICAR QUE ESTÃO OPERACIONAIS
 digitalWrite(ledRececao, HIGH);
 digitalWrite(10, HIGH);
 digitalWrite(ledInfo, LOW);
 digitalWrite(ledRececao, LOW);
 PgmPrint("Memoria RAM Livre: ");
 Serial.println(FreeRam());
 //INICIALIZA O CARTÃO SD EM "FULL SPEED", MÁXIMO DESEMPENHO. (PARA EVITAR ERROS COM LIGAÇÃO À BREADBOARD DEVE ESTAR EM "HALF SPEED")
 if (!card.init(SPI_FULL_SPEED, 4)) error("Falha ao inicializar o Cartão SD!");
 //INICIALIZA O VOLUME FAT
 if (!volume.init(&card)) error("Falha ao inicializar Volume do Cartão SD!");
 PgmPrint("O volume e FAT");
 Serial.println(volume.fatType(),DEC);
 Serial.println();
 //LISTA NA SÉRIE OS FICHEIROS QUE ESTÃO NA RAIZ DO CARTÃO SD, COM DATA E TAMANHO
 if (!root.openRoot(&volume)) error("Falha ao abrir raiz do cartao!");
 PgmPrintln("Ficheiros na raiz do cartao:");
 root.ls(LS_DATE | LS_SIZE);
 Serial.println();
 //LISTA OS FICHEIROS DE TODOS OS DIRECTÓRIOS DO CARTÃO SD
 PgmPrintln("Ficheiros encontrados em todos os directorios do cartao:");
 root.ls(LS_R);
 Serial.println();
 PgmPrintln("Concluida a inicializacao do Cartao SD");
 //ESCREVE O CABEÇALHO DO FICHEIRO DE DATALOGGER
 Log = file.open(&root, ficheiroLog, O_WRITE | O_APPEND);
 if (Log){
   file.println("Leitura  ,  Nivel Tanque  ,  Quantidade Agua");
   file.close();
   Serial.println(F("Escrita do header no ficheiro LOG concluida!"));
 else{
   Serial.println(F("ERRO! Nao foi possivel abrir o ficheiro LOG."));
   //SE NÃO CONSEGUIR ABRIR O FICHEIRO LOG, LED FICA A PISCAR PARA INDICAR AVARIA
   while(true) {
 //INICIA O SERVIDOR
 Ethernet.begin(mac, ip);
 server.begin();
 delay(100);
 //CONFIGURA E INICIA O RECEPTOR
 vw_set_rx_pin(pinoRececao);
 vw_setup(2000);
 vw_rx_start();
 //LED PISCA 3 VEZES A INDICAR TODA A CONFIGURAÇÂO CONCLUÍDA COM SUCESSO
 for (int i = 0; i<3; i++) {
   delay(250);
   delay(250);
 Serial.println(F("Configuracao Concluida"));
 rececaoRF();
 clienteLigado();
//RECEPÇÃO DOS DADOS POR RF 433MHz
void rececaoRF() {
 byte buf[VW_MAX_MESSAGE_LEN];
 byte buflen = VW_MAX_MESSAGE_LEN;
 if (vw_get_message(buf, &buflen)) {
   for (int j = 0; j<buflen; j++) {
     mensagem[j] = buf[j];
   if (mensagem[0] == 'R') {
     dadosAgua = atoi(&mensagem[1]);
     percentAgua();
   else if (mensagem[0] == 'B') {
     dadosBat = atoi(&mensagem[1]);
     litrosAgua();
   Serial.print(F("Mensagem Recebida: "));
   Serial.println(mensagem);
   memset(&buf, 0, sizeof(buf));
   memset(&mensagem, 0, sizeof(mensagem));
   gravarDados();
 Serial.println(F("RececaoRF Concluida"));
void percentAgua() {
 percentagem = ((465-dadosAgua)*100)/465;
 Serial.print(F("Percentagem: "));
 Serial.println(percentagem);
void litrosAgua() {
 litros = ((465-dadosAgua)*700000)/465;
 Serial.print(F("Litros: "));
 Serial.println(litros);
void gravarDados() {
 if (Log){
   file.print(nrLeitura);
   file.print("  ,  ");
   file.print(percentagem, 1);
   file.print("  ,  ");
   file.println(litros);
   file.close();
   Serial.println(F("Valores gravados com sucesso!"));
   nrLeitura++;
   Log = false;
 else {
   Serial.println(F("ERRO ao gravar dados no ficheiro LOG!"));
blastboot
#1
Mar 11, 2013, 05:36 pm Last Edit: Mar 11, 2013, 05:37 pm by blastboot Reason: 1
void clienteLigado() {
 char clientline[BUFSIZ];
 char* ficheiroLer;
 int index = 0;
 Serial.println(F("variaveis feito"));
 client = server.available();
 Serial.println(F("client server available feito"));
 if (client) {
   Serial.println(F("Cliente ligado-------------------------"));
   index = 0;
   while (client.connected()) {
     if (client.available()) {
       char c = client.read();
        if (c != '\n' && c != '\r') {
     clientline[index] = c;
     index++;
     if (index >= BUFSIZ) {
       index = BUFSIZ - 1;
       continue;
        clientline[index] = 0;
        Serial.println(clientline);
        delay(1);
        if (strstr(clientline, "GET / ") != 0) {
          client.println();
          ficheiroLer = ficheiroIndex;
          lerFicheiroCartao();
        else if (strstr(clientline, "GET /tanque") != 0) {
          client.println("Content-Type: image/jpeg");
          client.println();
          ficheiroLer = ficheiroTanque;
        else if (strstr(clientline, "GET /border") != 0) {
          client.println();
          ficheiroLer = ficheiroBorder;
        else if (strstr(clientline, "GET /rodape") != 0) {
          client.println();
          ficheiroLer = ficheiroRodape;
        else if (strstr(clientline, "GET /iframe") != 0) {
          client.println();
          ficheiroLer = ficheiroIframe;
          client.println(F("<html><body>"));
          client.println(F("<div id=\"outer\">"));
          client.print(F("<div id=\"inner\" style=\"height:"));
          client.print(percentagem, 1);
          client.println(F("%\">"));
          client.println(F("</div></div>"));
          client.println(F("</p></body></html>"));
        else if (strstr(clientline, "GET /2iframe") != 0) {
          client.println();
          ficheiroLer = ficheiro2Iframe;
          if (percentagem >= 90 || percentagem <=10){
             client.println(F("<table width=\"210\" height=\"42\" border=\"0\" cellpadding=\"1\" cellspacing=\"1\">"));
             client.println(F("<tr>"));
             client.print(F(" <td width=\"69\" height=\"40\" class=\"iframe2\"><div align=\"center\"><b><font color=#E60000>"));
             client.println(F("%</font></b></div></td>"));
             client.print(F("<td width=\"134\" class=\"iframe2\"><div align=\"center\"><b><font color=#E60000>"));
             client.print(litros);
             client.print(F("</font></b></div></td>"));
             client.println(F("</tr>"));
             client.println(F("</table>"));
           else {
             client.print(F(" <td width=\"69\" height=\"40\" class=\"iframe2\"><div align=\"center\"><b>"));
             client.println(F("%</b></div></td>"));
             client.print(F("<td width=\"134\" class=\"iframe2\"><div align=\"center\"><b>"));
             client.print(F("</b></div></td>"));
        else if (strstr(clientline, "GET /&logg") != 0) {
          client.println("Content-Disposition: attachment; filename=\"Ficheiro_LOG_Tanque.txt\"");
          client.println();
          ficheiroLer = ficheiroLog;
        else {
         client.println("HTTP/1.1 404 Not Found");
         client.println();
         client.println("<h2>Erro 404</h2>");
         client.println("<s2>O caminho ou ficheiro especificado nao existe.<s2>");
         client.println("");
        break;
   delay(1);
   delay(2);
   client.stop();
 Serial.println(F("ClienteLigado Concluida"));
void lerFicheiroCartao() {
 boolean ficheiro = false;
 ficheiro = file.open(&root, ficheiroLer, O_READ);
 if (ficheiro) {
         byte clientBuf[64];
         int clientCount = 0;
         while(file.available()) {
           clientBuf[clientCount] = file.read();
           clientCount++;
           if (clientCount > 63) {
             client.write(clientBuf, 64);
             clientCount = 0;
           if (clientCount > 0) {
             client.write(clientBuf, clientCount);
           file.close();
           ficheiroLer = '\0';
 Serial.println(F("LerFicheiroCartao Concluida"));
Because the code is a little big i had to put it in two parts...
Many Serial.println was there for me to try to find the issue.
Many thanks in advance!
blastboot
#2
Mar 11, 2013, 06:42 pm Last Edit: Mar 11, 2013, 06:44 pm by blastboot Reason: 1
OK, i think this forum has good vibes! Meanwhile i've just discovered the issue... i have to put
EthernetServer server = EthernetServer(80);
and
char* ficheiroLer;
must be a global variable because of lerFicheiroCartao(); function... but compiler doesn't give me any error code.
and now it is working... that part!
I'm experienced that when arduino is given the index.htm file and images it resets a lot of times, and some of them are not displayed on browser...
blastboot
#3
Mar 11, 2013, 06:57 pm Last Edit: Mar 11, 2013, 07:01 pm by blastboot Reason: 1
I'm having this on serial monitor...
Memoria RAM Livre: 284
O volume e FAT16
IFRAME.HTM     2013-02-04 17:01:50 816
INDEX.HTM      2013-03-11 17:19:04 10934
TANQUE.JPG     2013-01-30 17:23:20 73287
2IFRAME.HTM    2013-02-04 16:57:22 359
BORDER.JPG     2013-02-01 13:44:54 110590
&LOGG.TXT      2013-03-01 14:13:58 9338
FAVICON.ICO    2013-01-17 19:48:32 4150
IFRAME.HTM
INDEX.HTM
2IFRAME.HTM
&LOGG.TXT
FAVICON.ICO
GET P? Concluida
GET / HTTP/1,\(                E,§   @G  Ãfiguracao Concluida
GET / HTTP/1,\(                E,§   @G  Ãfiguracao Concluida?...Memoria RAM Livre: 284
O volume e FAT16
&LOGG.TXT      2013-03-01 14:13:58 9384
IFRAME.HTM
INDEX.HTM
2IFRAME.HTM
&LOGG.TXT
FAVICON.ICO
Configuraciguracao Con
As you can see, Ethernet shield restarts a lot of time and browser stays like "thinking" and stays this for a long time...
SurferTim
If it restarts, then it has probably run out of SRAM. I recommend finishing what you apparently started, and use the F() function on all static strings. I see a bunch that are still not using the F() function.
SurferTim
every client.print ?
Every Serial.print(), Serial.println(), Serial.write(), client.print(), client.println() and client.write() with a static string should use the F() function. Otherwise, those strings are copied into SRAM.
blastboot
Thanks a lot! It worked and now my program works fine  :D
Another thing when i see "Memoria RAM Livre: 284" (equal to "Free RAM Memory: 284"  when SD Card initializes, this tells that i have 284 bytes of RAM memory available or no?
SurferTim
That sounds about right.
blastboot
So why did it run out of memmory? (just to understand that  :D )
SurferTim
That part is easy! Count up all the characters in the client.print() and client.println() static strings that were not using the F() function. If that exceeded 284...crash!
PaulS
It doesn't take a lot of string literals to eat up 284 bytes of SRAM.
blastboot
got it! so that "free memmory" will be used by client.print and serial.print commands during it's loop... I thought that when we compile the program the compiler checks that :\
