Topic: multiplier (Read 8764 times) previous topic - next topic
domo
What i dont understand is, if there is a DAC, then hasnt the output become analogue? where does it turn dc again?
domo
#31
Apr 08, 2013, 04:15 pm Last Edit: Apr 14, 2013, 12:39 am by domo Reason: 1
When i connect up the circuit, it does not seem to work. I am inputting the output
dc42
Which circuit have you built? I suggest you also post a photo of your wiring.
domo
#33
Apr 08, 2013, 04:35 pm Last Edit: Apr 14, 2013, 12:38 am by domo Reason: 1
I have built the buffer without the transistor system and the external secondary voltage input.
dc42
If you build the circuit as I described it, then I will try to help you get it working. If you leave bits out, you're on your own.
domo
#35
Apr 09, 2013, 02:31 pm Last Edit: Apr 14, 2013, 12:38 am by domo Reason: 1
photo1 just shows the wiring after op-amp and before HVM.
When i attempt to put in a second voltage input it doesn't work, therefore i tried to test the circuit by building whats on photo 2, which works but the output is not ideal.
