Topic: ERRO IN SERIAL bluettoth program (Read 956 times) previous topic - next topic
nstm91
i have G Board with xpro and i wont to configure my btbee and try to load this code..
#include <NewSoftSerial.h>   //Software Serial Port
#define RxD 2
#define TxD 3
NewSoftSerial blueToothSerial(RxD,TxD);
    Serial.begin(9600);          //Serial port for debugging, Comment this line if not required
    pinMode(RxD, INPUT);
    pinMode(TxD, OUTPUT);
    setupBlueToothConnection();
  if(blueToothSerial.read() == 'a')
    blueToothSerial.println("You are connected to Bluetooth Bee");
    //You can write you BT communication logic here
void setupBlueToothConnection()
    Serial.print("Setting up Bluetooth link");       //For debugging, Comment this line if not required
    blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
    sendBlueToothCommand("\r\n+STWMOD=0\r\n");
    sendBlueToothCommand("\r\n+STNA=modem\r\n");
    sendBlueToothCommand("\r\n+STAUTO=0\r\n");
    sendBlueToothCommand("\r\n+STOAUT=1\r\n");
    sendBlueToothCommand("\r\n+STPIN=0000\r\n");
    delay(2000); // This delay is required.
    blueToothSerial.print("\r\n+INQ=1\r\n");
    Serial.print("Setup complete");
void sendBlueToothCommand(char command[])
    char a;
    blueToothSerial.print(command);
    Serial.print(command);                          //For debugging, Comment this line if not required
    delay(3000);
    while(blueToothSerial.available())              //For debugging, Comment this line if not required
    {                                               //For debugging, Comment this line if not required
       Serial.print(char(blueToothSerial.read()));  //For debugging, Comment this line if not required
    }                                               //For debugging, Comment this line if not required
but this provide some error
In file included from Bluettoth.ino:2:
C:\Documents and Settings\suresh\My Documents\Arduino\libraries\GSM_Shield/NewSoftSerial.h:71: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
I:\arduino-1.5.2-windows\arduino-1.5.2\hardware\arduino\avr\cores\arduino/Print.h:48: error:   overriding 'virtual size_t Print::write(uint8_t)'
PaulS
Code: [Select]
is incompatible with
Quote
You should be using SoftwareSerial, instead.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
