Topic: Arduino circuit with 2 switches and two 12v dc motors (Read 1 time) previous topic - next topic
ElectronicalRetard
Hi there,
I need to get hold of a very basic circuit that will use the arduino board to drive two 12v dc motors, the circuit also needs to have two on/off switches one for each motor.
JimboZA
First have a look at this which will show you how to use a switch
Then, here you can see how to drive a dc motor.
Then think about how to put the two together, and how to double up for two switches and motors.
73 de ZS6JMB
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
ElectronicalRetard
Hello,
Okay thank you. I've had a look at the pages, I understand the components themselves but need a hand in terms of a schematic and how to put them together.
Thank you
JimboZA
#3
Mar 12, 2013, 05:37 pm Last Edit: Mar 12, 2013, 05:43 pm by JimboZA Reason: 1
Well, instead of turning on the LED, think that that pin could be the one that connects to the transistor and turns the transistor on and off.
So basically, to drive one motor, you could use the sketch that drives the LED, along with its switch, but amalgamated with the circuit of the transistor / motor to connect to that pin and Voila!
Then have a think about how to do it for two.
Edit.... This site is very good as a place to start on the electronics, especially of the components.
73 de ZS6JMB
