Topic: mobile robot localization (Read 4639 times) previous topic - next topic
abdelrazzaqhiasat
hi
i'm working on a mobile robot project..in this project the robot should work in an indoor area of 100 m2.so i will have to define a coordination system (or what it is called) to let the robot know where it is and where to go.
so what do you recommend me to use....exp(cameras or ultrasonic sensors..... ) (i suppose that the gps wont be accurat)
note: the cost of this system is an issue
sorry for my bad english
thnx
PaulS
This really belongs in Robotics, where you will learn all about the difficulties involved in what you are trying to do. Or, you would if you read anything there, first.
abdelrazzaqhiasat
hi
thnx
CrossRoads
I would go with something that will not reflect and allow for valid reception from what may appear as more than 1 source.
GPS will not work well (at all?) indoors - need to see the sky to receive a signal from a satellite.
Will the robot have clear view of 2 corners of the area at all times? You could have 2 infrared transmitters with 2 frequencies.
The robot would have an IR receiver (or 2) that could measure the angle between the 2 and compute its location.
If you can't eliminate reflection, then maybe implement scanning & just measure the angle between the 2 strongest transmitters.
abdelrazzaqhiasat
yes the workspace of the robot is a square room of (10x10m) so i can install two transmitter .... but how am i going to be able to mesure the angle between them?? :smiley-red: :smiley-red:
should i install the receiver on a servo motor??
i know that i'm asking alot but....can you give links to similar project :)
thanks
AWOL
Topics merged.
@OP : DO NOT CROSS-POST.
If you posted in the wrong section, ask a moderator to move it for you.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
CrossRoads
Yes, find one, use a servo with microstep control to find the other.
I don't know anyone doing it like that, but it makes sense to me mathematically.
You couldn't make a determination if you were on straight line in between them, and there would be a 50/50 shot of being in one half or the other.
So ideally three would make more sense so you could resolve which half you were on.
zoomkat
Quote
That would be what I would try. You could get one of the below IR receiver modules at RS for the IR detector and use a TV remote from the dollartree store for the test beacon. Put the detector in a black non reflective shield tube and point it at the tv remote to see if the detector can detect the remote.
http://www.radioshack.com/product/index.jsp?productId=2049727#
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
oric_dan
You might get some ideas from Borenstein's book "Where Am I?", downloadable online
from his website. Chap 6, Active Beacon Systems.
http://www-personal.umich.edu/~johannb/
CrossRoads
Excellent - Chapter 6, discusses various ways to determine location in 10meterx10meter room.
http://www-personal.umich.edu/~johannb/Papers/pos96rep.pdf
abdelrazzaqhiasat
