Loading...
Pages: [1]   Go Down
Author Topic: data overflow  (Read 197 times)
Offline Offline
Newbie
View Profile
i'm doing a line follower using cmucam4 camera and a sugeno fuzzy system to control the car.
the problem goes like this: when i process the image data and send them into the fuzzy system, the data show overflow(shown in serial monitor). some of the If Then statement become true event the condition does no meet.
for (int y=14; y<49; y=y+2)  // read the image
    int blackcount=0;
    int blacksum=0;
    for (int x=9; x<70; x++)
      if(cam.getPixel(&f_data,y,x)==1)
        blackcount=blackcount+1;
        blacksum=blacksum+x;
    if (blackcount==0)
      centroid_x=0;
      centroid_y=0;
      centroid_x=blacksum/blackcount;  //calculate the line centroid
      centroid_y=y;
      N=N+1;
i take 18 lines for the calculation, then i calculate the final target point.
target_x=total_x/N; //N is the lines ** if i assign target_x and target_y with number, the system works,
target_y=total_y/N;                       ** but if i use the calculation value and send it to the fuzzy, the whole things goes worng.
then target_x and target_y will feed into fuzzy system
if ((target_x>9.0&&target_x<=27.0)&&(target_y>0.0 &&target_y<=10.0))  // rule 1
      if (target_x>9.0&&target_x<=18.0)
      rulex1=target_x/(9.0)-1.0;
      else if(target_x>18.0&&target_x<=27.0)
      rulex1=target_x/(-9.0)+3.0;
      rulex1=0.0;
      if (target_y>0.0&&target_y<=5.0)
      ruley1=target_y/(5.0);
      else if(target_y>5.0&&target_y<=10.0)
      ruley1=target_y/(-5.0)+2.0;
      ruley1=0.0;
      output1=min(rulex1,ruley1);
      steering1=abs(output1)*77.0;
      speed1=abs(output1)*150.0;
there are 21 rules.
can anyone help me????
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
http://snippets-r-us.com might be able to help you with the improperly posted snippets. Here, we expect to see ALL of your code, properly posted.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
How to use this forum
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
http://snippets-r-us.com might be able to help you ...
Whoa ...
Quote
Firefox can't find the server at snippets-r-us.com.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Isn't that rather the point?
Logged
Offline Offline
Newbie
View Profile
this is the code:
Code:
#include <CMUcam4.h>
#include <CMUcom4.h>
#include <Servo.h>
Servo sservo;
int motor = 10;
int ENDL = 22;
#define RED_MIN 0
#define RED_MAX 30
#define GREEN_MIN 0
#define GREEN_MAX 30
#define BLUE_MIN 0
#define BLUE_MAX 30
#define LED_BLINK 5 // 5 Hz
#define WAIT_TIME 5000 // 5 seconds
CMUcam4 cam(CMUCOM4_SERIAL3);
  cam.begin();
  cam.LEDOn(LED_BLINK);  // Wait for auto gain and auto white balance to run.
  delay(WAIT_TIME);
  cam.lineMode(true);
  cam.cameraBrightness(-120);
  cam.cameraContrast(30);
  cam.LEDOn(CMUCAM4_LED_ON);
  sservo.attach(8);
  sservo.write(90);
  pinMode(motor,OUTPUT);
  pinMode(ENDL,OUTPUT);
  digitalWrite(ENDL,HIGH);
  int N=0;
  float rulex1, rulex2, rulex3, rulex4, rulex5, rulex6, rulex7, rulex8, rulex9, rulex10, rulex11, rulex12, rulex13, rulex14, rulex15, rulex16, rulex17, rulex18, rulex19, rulex20, rulex21 =0;
  float ruley1, ruley2, ruley3, ruley4, ruley5, ruley6, ruley7, ruley8, ruley9, ruley10, ruley11, ruley12, ruley13, ruley14, ruley15, ruley16, ruley17, ruley18, ruley19, ruley20, ruley21 =0;
  float output1, output2, output3, output4, output5, output6, output7, output8, output9, output10, output11, output12, output13, output14, output15, output16, output17, output18, output19, output20, output21 =0;
  float steering1, steering2, steering3, steering4, steering5, steering6, steering7, steering8, steering9, steering10, steering11, steering12, steering13, steering14, steering15, steering16, steering17, steering18, steering19, steering20, steering21 =0;
  float speed1, speed2, speed3, speed4, speed5, speed6, speed7, speed8, speed9, speed10, speed11, speed12, speed13, speed14, speed15, speed16, speed17, speed18, speed19, speed20, speed21 =0;
  float motor_speed;
  int steering_angle;
  float centroid_x=0;
  float centroid_y=0;
  float total_x=0;
  float total_y=0;
  float target_x=0;
  float target_y=0;
  CMUcam4_image_data_t f_data;
  CMUcam4_tracking_data_t t_data;
  cam.trackColor(RED_MIN, RED_MAX, GREEN_MIN, GREEN_MAX, BLUE_MIN, BLUE_MAX);
  cam.getTypeTDataPacket(&t_data); // Get a tracking packet.
  cam.getTypeFDataPacket(&f_data); // Get an image packet.
    int blackcount=0;
    int blacksum=0;
    if (blackcount==0)
      centroid_x=0;
      centroid_y=0;
      centroid_y=y;
      N=N+1;
    total_x=total_x+centroid_x;
    total_y=total_y+centroid_y;
  if (N!=0)
    target_x=total_x/N;
    target_y=total_y/N;
    Serial.print("targetx=");
    Serial.print(target_x);
    Serial.print(" targety=");
    Serial.println(target_y);
      rulex1=0.0;
      ruley1=0.0;
    if ((target_x>9.0&&target_x<=27.0)&&(target_y>5.0&&target_y<=15.0))  // rule 2
      rulex2=target_x/(9.0)-1.0;
      rulex2=target_x/(-9.0)+3.0;
      rulex2=0.0;
      if (target_y>5.0&&target_y<=10.0)
      ruley2=1.0/5.0*target_y-1.0;
      else if(target_y>10.0&&target_y<=15.0)
      ruley2=(-1.0/5.0)*target_y+3.0;
      ruley2=0.0;
      output2=min(rulex2,ruley2);
      steering2=abs(output2)*77.0;
      speed2=abs(output2)*110.0;
    if (target_x>9&&target_x<=27&&target_y>10&&target_y<=20)  // rule 3
      rulex3=1.0/9.0*target_x-1.0;
      rulex3=-1.0/9.0*target_x+3.0;
      rulex3=0.0;
      if (target_y>10.0&&target_y<=15.0)
      ruley3=1.0/5.0*target_y-2.0;
      else if(target_y>15.0&&target_y<=20.0)
      ruley3=(-1.0/5.0)*target_y+4.0;
      ruley3=0;
      output3=min(rulex3,ruley3);
      steering3=abs(output3)*60.0;
      speed3=abs(output3)*110.0;
    if ((target_x>9&&target_x<=27)&&(target_y>15&&target_y<=35))  // rule 4
      rulex4=1.0/9.0*target_x-1.0;
      rulex4=-1.0/9.0*target_x+3.0;
      rulex4=0.0;
      if (target_y>15&&target_y<=25)
      ruley4=1.0/10.0*target_y-1.5;
      else if(target_y>25&&target_y<=35)
      ruley4=(-1.0/10.0)*target_y+3.5;
      ruley4=0.0;
      output4=min(rulex4,ruley4);
      steering4=abs(output4)*60;
      speed4=abs(output4)*75;
    if ((target_x>9&&target_x<=27)&&(target_y>25&&target_y<=59))  // rule 5
      if (target_x>9.0&&target_x<=18)
      rulex5=1.0/9.0*target_x-1.0;
      rulex5=-1.0/9.0*target_x+3.0;
      rulex5=0.0;
      if (target_y>25.0&&target_y<=42)
      ruley5=1.0/17.0*target_y-25.0/27.0;
      else if(target_y>42.0&&target_y<=59)
      ruley5=(-1.0/17.0)*target_y+59.0/17.0;
      ruley5=0.0;
      output5=min(rulex5,ruley5);
      steering5=abs(output5)*60;
      speed5=abs(output5)*75;
  float total_output=output1+output2+output3+output4+output5+output6+output7+output8+output9+output10+output11+output12+output13+output14+output15+output16+output17+output18+output19+output20+output21;
  steering_angle=(steering1+steering2+steering3+steering4+steering5+steering6+steering7+steering8+steering9+steering10+steering11+steering12+steering13+steering14+steering15+steering16+steering17+steering18+steering19+steering20+steering21)/total_output;
  motor_speed=(speed1+speed2+speed3+speed4+speed5+speed6+speed7+speed8+speed9+speed10+speed11+speed12+speed13+speed14+speed15+speed16+speed17+speed18+speed19+speed20+speed21)/total_output;
  Serial.print(steering_angle);
  Serial.print("  ");
  Serial.println(motor_speed);
   sservo.write(steering_angle);
   analogWrite(motor,motor_speed);
   sservo.write(90);
   analogWrite(motor,0);
  Serial.print("  steering angle=");
  Serial.print("  running speed=");
  // Do something else here.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
You got something against carriage returns?
How about arrays?
Logged
Offline Offline
Newbie
View Profile
actually i use arrays to store the velue, but i having problem in that.
Code:
if (blackcount==0)
      centroid_x=0;
      centroid_y=0;
      centroid_y=y;
      N=N+1;
i use arrays to store the centroid_x and centroid_y, but these two arrays give me the same result, which is not right. so, i declare all the variable. i will change to arrays after i done with the fuzzy problem.
the problem is whenever i use the
target_x=total_x/N;
target_y=total_y/N;
to the fuzzy system, the system goes wrong, if i give value to the target_x and target_y, the system ok. i try to print out the target_x and target_y, the values are ok. whats going wrong actually??
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
    int blackcount=0;
    int blacksum=0;
What do these magic numbers mean?
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Code:
Put the arrays back, this is ridiculous.
Logged
Finland
Offline Offline
Jr. Member
View Profile
Code:
Take a close look at this line. See the init only on the last float? You have an overflow because all the rest are random. I'm sorry but the code was a little tl;dr with too many variables for me to be able to tell where they all still initialized to some value, but that's what caught my eye as a curiosity.. Just use the array and initialize them in a loop.
Logged
UK
Offline Offline
Tesla Member
View Profile
That is utterly bonkers. I think you're completely wasting your time with that approach - and ours.
Logged
Pages: [1]   Go Up
Print
Jump to:
