Author Topic: DUE Eagle file  (Read 973 times)
UK
I've created an Eagle library file for the DUE to make it easier to create shields/prototyping boards.
I thought I would share it with you nice people smiley
I can't work out how to delete the extra "Package" of a MEGA shield but will sort it and upload another later.
Thanks to MMCPIX for original Mega shield.
« Last Edit: April 25, 2013, 01:26:26 pm by cowasaki » Logged
FYI, the header with pins 8, 9, 10 etc. needs to be at the weird 'mistake' position, not on the 0.05" grid. You can get the correct positions from the Eagle files for Uno etc.
Also worth considering adding bRestrict pads so that the autorouter doesn't try to route a pad to the bottom side of a Due connector pin - you can't solder those because the connector body is in the way. I've also found it useful to add vRestrict areas to prevent Eagle from putting vias too close the connectors (but that's because I have to use pins for vias).
Hope that helps...
UK
Thanks, I will look at all that.....
UK
Just checked and the header 8-SCL1 lines up against my DUE....  This shield started life as my MEGA shield which I've made boards from and that lined up........  Or am I missing something.
UK
New version with better labels for debug header and shaping around the new pins that don't appear on the header.  Still looking at the bit about bRestrict pads.
I just had a look at the reference Eagle files and pin 8 seems to be 0.160" from pin 7. I suppose the extra 0.01" isn't enough to cause a problem.
UK
I've added a 2nd library with the restrict areas added.
UK
I've sussed out how to delete the spurious MEGA shield and merged the two DUE shields into one file.  New version uploading now.....
Hi and thanks first of all for the library.
As far as I can see the +5V and die GND of the SPI header should be switched. This caused a short in my first pcb smiley
Thanks anyways
USA, FL
A life? Where can I download one of those?
Yet, he's right, the 5V and GND pins need to be switched on the ICSP.
//LiNK
UK
Sorry about that chaps smiley-grin
I've fixed it now (hopefully).
UK
Standby.....  Just fixing it again!!
UK
I really have fixed it now smiley
