« Reply #1 on: March 13, 2013, 07:48:56 pm » |
So can you explain more how the slide operates, what sort of forces and speeds are involved?
« Reply #2 on: March 13, 2013, 07:59:15 pm » |
Think of the robot as a CNC router. I'm worried about the weight of the robot which is made from steel pieces. The modified servo is too slow. I use 8-32 threaded rod. I found these geared motors for $10.00 at http://www.campsolution.com/dc24v100rpmgearmotor2-1.aspx
« Reply #3 on: March 14, 2013, 02:14:26 am » |
I doubt that motor really is 0.8 watt
« Reply #4 on: March 14, 2013, 11:35:32 am » |
So what is the weight?, what is the servo that's too slow? - where are the specs needed to work out what kind of motor is needed... How fast? What torque?
« Reply #5 on: March 14, 2013, 02:51:29 pm » |
I tried a DC motor usually used in toys and it moved the sliding part fast enough. The size of the motor's can is 1-1/4 inches long and 1-1/8 inches in diameter. I built one of the four assemblies shown in the photo and I didn't build the chassis yet so I don't know how much the robot will weigh.
« Reply #6 on: March 14, 2013, 07:32:45 pm » |
Without an idea of the weight you can only guess about the motors.... At least decide a plausible upper limit or you have no starting place for sizing up things.
« Reply #7 on: March 14, 2013, 07:44:24 pm » |
I'm thinking of using drill motors with gearboxes for the sliding part of the robot. Harbor Freight has a 4.5V drill for $10 but I don't know what kind of DC motor the drill has. It may be a piece of junk. http://www.harborfreight.com/48-volt-cordless-screwdriver-kit-68394.html
« Reply #8 on: March 14, 2013, 09:36:15 pm » |
« Reply #9 on: March 15, 2013, 02:47:07 pm » |
I'm going to buy the 6V cordless screwdriver at K-Mart for $9.99.
« Reply #10 on: March 16, 2013, 01:25:16 pm » |
I think that the 6v cordless screwdriver is too slow for the sliding part of the robot. I tried a 18V cordless drill that I already have and it was fast enough but the drill is too big and too heavy.
« Reply #11 on: March 17, 2013, 01:12:19 pm » |
I don't know how to take the 6V cordless screwdriver apart because there are no screws holding the orange body together. If I take the metal "U" shaped pin out, I see a two-stage planetary gearbox. I tried to search the Internet but I can't find anything about the Black & Decker AS6NG 6V cordless screwdriver. I found out that there is Black & Decker AD600 screwdriver with more torque. Both screwdrivers spin at 130 RPM. My Ryobi P200 cordless drill runs up to 1300 RPM and has 400 in.-lb. of torque. Any suggestions?
Westbrook, CT
"Why should I bother with made-up games when there are so many real ones going on." (c) Kurt Vonnegut
« Reply #12 on: March 18, 2013, 09:40:16 am » |
A servo Might do the job for short distance otherwise consider a stepper motor.
Arduino Uno R3 Mac OSX Lion
