Topic: How to estimate number of hours remaining before battery dies? (Read 4766 times) previous topic - next topic
retrolefty
Predicting "remaining life" is difficult.
OTOH knowing when it's "nearly dead" isn't. Most batteries go down to about 1.1V then drop off very quickly (think "cliff").
Indeed - any you need to know the actual chemistry of the battery involved, AA cells might be Zinc/carbon, alkaline,
NiMH or even NiCd or NiZn!  Unless you know the chemistry you can't know which voltage represents the death-knell
of the cell.  For NiCd for instance its such a flat curve that in practice you can't tell, fortunately with NiMH you can
fairly well.
  So you probably need to decide on a single type of cell to get a reasonably reliable indication.
It's been my experience that Nicad and MiMH have very similar flat discharge curves where the terminal voltage does not give you a good indication of remaining charge until it's almost at the end.
http://www.mpoweruk.com/performance.htm
Lefty
MisterResistor
Remember all those milliamps are in relation to milliamp hours. So, the 1 ma timer draw = approximately 25 ma in a day. The 50 ma draw is only happening 40 seconds out of an 86,400 second day. A 2500 ma battery will last least a month.  Your mileage may vary!
JimboZA
Quote
You mean....
25mA hours
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Nick Gammon
Quote
You mean....
25mA hours
In Australia, it would be 24 hours in the day. YMMV.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
sonnyyu
Hi guys,
I am doing a battery life indicator for a device. A red led will light up when the voltage reaches below a certain limit, which is at least 2 days before the AA battery fully dies.
As such, I want to know how to determine the number of days left before a AA battery dies. I have attached the datasheet for a AA battery but it only shows the constant current performance chart. My device draws around 50ma current for about 10seconds, 4 times a day, when a motor rotates. And all along, it draws a current (ard 1ma I think) when it runs a timer.
So, how can I determine the voltage when the battery is abt 48hours before "dying"?
you need battery monitor IC which support Battery Fuel Gauge/Gas Gauge.
one sample from ST;-
STC3105
make sure select IC type match with battery type.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
