Topic: HiTechnic Motor Controller (Read 3195 times) previous topic - next topic
Soapy29
Mar 13, 2013, 05:24 am Last Edit: Mar 13, 2013, 05:43 am by Soapy29 Reason: 1
Hello. I was wondering if it would be possible to have one or many HiTechnic Motor Controllers interfaced with Arduino. They are I2C, but I don't know anything about that. I am using UNO R3.
CrossRoads
What's a Tetrix Motor Controller?  Got a link?
Soapy29
#2
Mar 13, 2013, 05:41 am Last Edit: Mar 15, 2013, 01:44 am by Soapy29 Reason: 1
Whoops, meant to say HiTechnic DC Motor Controller. http://www.legoeducation.us/eng/product/hitechnic_dc_motor_controller/1648
Edit: I think I found a PDF that would be useful: http://www.legoeducation.us/etc/supportFiles/TETRIX/739413/HiTechnicMotorControllerBriefv1.3.pdf
Soapy29
#3
Mar 15, 2013, 12:07 am Last Edit: Mar 15, 2013, 01:43 am by Soapy29 Reason: 1
So for the code, I know I need to use the Wire library for I2C communications. Basically, I would be sending motor 1, or address 02, a value for the motor speed, right? I know in Labview for FTC, the motor values go from 0-255, so I don't know if they are the same here or not.
And also, how would I wire it to my Arduino? I was thinking of just stripping the wires, or using this breakout: https://store.wayneandlayne.com/products/bricktronics-breakout-board.html
Basically, I don't know exactly how to approach this project, but I have ideas how.
Edit: I found a website with how the wires are layed out in the connector. http://www.mindsensors.com/index.php?module=pagemaster&PAGE_user_op=view_page&PAGE_id=136
I have an Uno R1 & R3, so SDA goes to A4, and SCL goes to A5, correct? And of course, 5V to 5V, and GND to GND.
Also found another picture with what the 6th lead is, and color codes:
Soapy29
Reading the spec sheet for the controller, the range for the speed goes from -100 to 100. 45H and 47H are power for each motor. So here is how I think I would write the code:
#include <Wire.h>
byte speed = 100;
  Wire.begin(); // join i2c bus
  Wire.beginTransmission(0x02); // transmit to device #44 (0x2c)
                              // device address is specified in datasheet
  Wire.write(speed);             // sends value byte
  Wire.endTransmission();     // stop transmitting
That should send 100 to address 0x02 every half second, but how does it know to set motor one to 100? Do I have to send a string of data?
