Loading...
Pages: 1 [2]   Go Down
Author Topic: Pendulum Balance Robot  (Read 528 times)
Offline Offline
Full Member
View Profile
I'm pretty sure you need to use an interrupt
attach the encoder to pins 2 and 4
Code:
Encoder encoder(2, 4);
            attachInterrupt(0, doEncoder, CHANGE);
            Serial.begin (9600);
            Serial.println("start");
        void loop(){
            // do some stuff here - the joy of interrupts is that they take care of themselves
        void doEncoder(){
            encoder.update();
            Serial.println( encoder.getPosition() );
Logged
Offline Offline
Full Member
View Profile
It looks like you are using a different encoder library.  Seems to be several out there.  Just try using the encoder on different interrupt pins.
Logged
Offline Offline
Full Member
View Profile
Also try putting this bit in the setup
Code:
myEnc.write(-512);
You may be setting the encoder faster than the interrupt can update, also you won't get far from -512 as it is incremental and you are basically resetting it during the loop.
edit: and why -512 and not 0
« Last Edit: March 13, 2013, 12:19:08 pm by laadams85 » Logged
Offline Offline
Newbie
View Profile
Hey guys,  I have disabled the line setting the encoder at -512,  and now the encoder reads the value correctly.  smiley-grin Unfortunately the motor isnt working,  the output from the PID is still constant , despite the Position changing
Any thoughts,  I think its the PID causing the issues now,  as the encoder reads correctly,  and motor moves when an step is put in to it.
heres the code
Code:
#include <PID_v1.h>
#include <Encoder.h>
#include <Stepper.h>
const int pwmA = 3;
const int pwmB = 11;
const int brakeA = 9;
const int brakeB = 8;
const int dirA = 12;
const int dirB = 13;
const int STEPS = 200;
double m = 0;
double newPosition  = 0;
double Position = 0;
int chanA = 20;
int chanB = 21;
Stepper myStepper(STEPS, dirA, dirB);
Encoder myEnc(chanA, chanB);
PID myPID(&Position, &m, 0, 1, 20, 100, DIRECT);
  myStepper.setSpeed(90);
pinMode (pwmA, OUTPUT);
  digitalWrite(pwmA, HIGH);
  pinMode(pwmB, OUTPUT);
  digitalWrite(pwmB, HIGH);
  pinMode(brakeA, OUTPUT);
  digitalWrite(brakeA, LOW);
  pinMode(brakeB, OUTPUT);
  digitalWrite(brakeB, LOW);
long oldPosition  = -999;
  newPosition = myEnc.read();
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
    Position = ((newPosition/11.37)+180);
    if (Position > 180) {
    Position = Position -360;
    if (Position < -180) {
    Position = Position +360;
//Serial.println(Position);
  myPID.Compute();
  myStepper.step(int(m));
  Serial.println(int(&m));
Just for referance,  the  PID wants the motor to move 536 steps no matter the actual location, I'm not sure why.
« Last Edit: March 18, 2013, 11:05:12 am by Yewzorz » Logged
Offline Offline
Full Member
View Profile
I'm glad that you got the encoder to work properly.  To get the PID to work you are going to have to tune the PID.  There are several ways to do this, but I'll borrow from wikipedia for the easiest way.
-Set the I and D terms to zero.
-Increase the P term until the system oscillates.
Then set your values based on the table found here
http://en.wikipedia.org/wiki/Ziegler%E2%80%93Nichols_method
I would also suggest printing out the double value of m as well as the integer value of m.  Maybe it is changing but not enough to make a difference.
Code:
Serial.println(&m);
Logged
Offline Offline
Newbie
View Profile
Hi everyone,  unfortuantely I'm still having no luck,  the PID output it still remaining constant. I have tried normalising the position data between 0-1, however that has not given a response. Changing the P value has no effect on the output,  neither does changing the position. Has anyone got any thoughts on what might not be working?
Logged
Queens, New York
Offline Offline
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
View Profile
Is the PID on?
Quote
//turn the PID on
  myPID.SetMode(AUTOMATIC);
http://playground.arduino.cc//Code/PIDLibaryBasicExample
Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Pages: 1 [2]   Go Up
Print
Jump to:
