Topic: Modifications in function (Read 937 times) previous topic - next topic
harnam
Hello there !
In the following sketch, I was using  three reed switches and only one magnetic float(when the magnetic float was traveling upwards and downwards, it was making and breaking the reed switches) , now I want to use three separate  magnetic float switches (each switch will have its own reed switch and magnetic float)
What modifications, I need to do in the functions in this sketch?
Thanks
#include <EEPROM.h>
// INPUT PINS
#define Buttonpin1  2  //Tank Level1
#define Buttonpin2  3  //Tank Level2
#define Buttonpin3  4  //Tank Level3
#define Auto_Man_Buttonpin   5 //Auto/manual button
// OUTPUT PINS
#define LED1  8 //Tank1 Level1 Display
#define LED2  9 //Tank1 Level2 Display
#define LED3  10 //Tank2 Level1 Display
#define Auto_Man_Led  6  //Auto/manual operation
#define Pumppin 7 // Pin for water pump activation
// EEPROM MEMORY POSITIONS
#define memposL1  0  // set constant eeprom position 0 to save Level
// variables
int state=0;
int level = 0;
int lastlevel = 0;
void setup (){
// INPUTS
pinMode(Auto_Man_Buttonpin,INPUT);  // default mode is INPUT
pinMode(Buttonpin1,INPUT);               // default mode is INPUT
pinMode(Buttonpin2,INPUT);               // default mode is INPUT
pinMode(Buttonpin3,INPUT);               // default mode is INPUT
digitalWrite(Auto_Man_Button, HIGH);  // Turn on the internal pull-up resistor, default state is HIGH
digitalWrite(Buttonpin1, HIGH);     // Turn on the internal pull-up resistor, default state is HIGH
digitalWrite(Buttonpin2, HIGH);     // Turn on the internal pull-up resistor, default state is HIGH
digitalWrite(Buttonpin3, HIGH);     // Turn on the internal pull-up resistor, default state is HIGH
// OUTPUTS
pinMode(Pumppin, OUTPUT);
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(Auto_Man_Led, OUTPUT);
pinMode(LED3, OUTPUT);
// Restore tank water Level from eeprom
level = EEPROM.read(memposL1);  // Read from eeprom memPos1 the value of Level1
lastlevel = level;                          // also update the according lastLevel variable
if ((level == 0)||(level>3))            // if eeprom has illegal value
level=1;              // set level to 1 (minimum)
updateprom(); // call updateprom function to set eeprom memory value to minimum too.
setleds();       // restore the reed states from EEPROM stored value.
startstoppump();
// FUNCTION THAT SETS THE LEDS ACCORDING TO LEVEL VARIABLE WHENEVER CALLED
void setleds()
digitalWrite(LED1, LOW );
digitalWrite(LED2, LOW );
digitalWrite(LED3, LOW );
if (level > 0)   digitalWrite(LED1, HIGH );
if (level > 1)   digitalWrite(LED2, HIGH );
if (level > 2)   digitalWrite(LED3, HIGH );
// FUNCTION THAT CONTROLS THE PUMP OPERATION ACCORDING TO WATER LEVEL AND AUTO_MAN SETTING
 void  startstoppump(){
 if (level < 3)   digitalWrite(Pumppin, HIGH );
 if ((level == 3) & (state == 0))
 digitalWrite(Pumppin, LOW );
// FUNCTION THAT UPDATES EEPROM AT EACH LEVEL CHANGE
void updateprom()
{                           // UPDATE LEVEL 1
lastlevel = level;       // update lastLevel variable
EEPROM.write(memposL1, level);   // and store new Level value to eeprom
// MAIN LOOP
void loop ()
// TOGGLE AUTO/MANUAL MODE
 if ( (digitalRead(Auto_Man_Buttonpin) == LOW) & (state == 0) )
{                                                            // Button  pushed
state=1;
digitalWrite(Auto_Man_Led, state );            // Turn on the LED
startstoppump();
delay(400);
 if ( (digitalRead(Auto_Man_Buttonpin) == LOW) & (state == 1)  )
{                                                           // Button  pushed
 state=0;
 digitalWrite(Auto_Man_Led, state );        // Turn off the LED
  startstoppump();
 delay(400);
//END OF TOGGLE AUTO/MANUAL MODE
// CHECK WATER LEVEL
if ( digitalRead(Buttonpin1) == LOW  )
{                              // Button  pushed
level = 1;
if ( digitalRead(Buttonpin2) == LOW  )
{                               // Button  pushed
level = 2;
if ( digitalRead(Buttonpin3) == LOW  )
{                              // Button  pushed
level = 3;
//END OF CHECK WATER LEVEL
//  IF WATER LEVEL CHANGED AND CALL THE NECESSARY FUNCTIONS.
if (level != lastlevel)
setleds();
startstoppump();
updateprom();
 } // END OF MAIN LOOP
PaulS
First
thing
you
need
to
do
is
use
Tools
Auto
Format
to
make
the
code
readable.
AWOL
// OUTPUT PINS
If an input is a tank-level input, why not call it that?
If an LED indicates a tank-level, why not call it that?
harnam
Thanks for the tips
I am Sorry for the mess up, here is new format compiled code.
#include <EEPROM.h>
// CONSTANTS
// INPUT PINS
#define Level1  3
#define Level2  4
#define Level3  5
// OUTPUT PINS
#define LEDLevel1  8
#define LEDLevel2  9
#define LEDLevel3  11
#define Pumppin  13
#define memposL1  0  // set constant eeprom position 0 to save Level1
// variables
int state= 0;
int level = 0;
int lastlevel = 0;
void setup ()
  // INPUTS
  pinMode(Level1,INPUT);   // default mode is INPUT
  pinMode(Level2,INPUT);   // default mode is INPUT
  pinMode(Level3,INPUT);   // default mode is INPUT
  digitalWrite(Level1, HIGH);     // Turn on the internal pull-up resistor, default state is HIGH
  digitalWrite(Level2, HIGH);     // Turn on the internal pull-up resistor, default state is HIGH
  digitalWrite(Level3, HIGH);     // Turn on the internal pull-up resistor, default state is HIGH
  // OUTPUTS
  pinMode(LEDLevel1,    OUTPUT);
  pinMode(LEDLevel2,    OUTPUT);
  pinMode(LEDLevel3,    OUTPUT);
  {                               // if eeprom has illegal value
  startstoppump();
void setleds()
  digitalWrite(LEDLevel1, LOW );
  digitalWrite(LEDLevel2, LOW );
  digitalWrite(LEDLevel3, LOW );
  if (level > 0)   digitalWrite(LEDLevel1, HIGH );
  if (level > 1)   digitalWrite(LEDLevel2, HIGH );
  if (level > 2)   digitalWrite(LEDLevel3, HIGH );
//FUNCTION THAT CONTROL THE START AND TOP OF THE PUMP
  if (level == 1)
void updateprom()
// MAIN LOOP
void loop ()
  if ( digitalRead(Level1) == LOW  )
    level = 1;
  if ( digitalRead(Level2) == LOW  )
    level = 2;
  if ( digitalRead(Level3) == LOW  )
    level = 3;
    setleds();
    startstoppump();
    updateprom();
PaulS
Should that be && in the middle? I can't see how a bitwise and is useful.
In your code, I can't see that changing the mechanism for triggering the switch will make any difference. The switches are still HIGH or LOW, regardless of what caused them to be HIGH or LOW.
Groove
in this particular case it should work as well as logical AND, but I agree it should &&
Per Arduino ad Astra
wildbill
More to the point, why are you testing state at all - you never change it.
What's the purpose of the change to three float switches?
harnam
Thanks Mr. PaulS,
You are right, I will change it to &&.
Thanks Mr. Wildbill
This one float system sometime mal-functions. Another problem is that if the water falls below the
Minimum i.e. level1 the indicator ledLevel1 remains ON. What is the solution to this problem ?
