Loading...
Pages: [1]   Go Down
Author Topic: Push button to start an array  (Read 1714 times)
Offline Offline
Newbie
View Profile
I am a first time user of arduino, and am using it for an art project. I want to use a push button to start and stop an array that is hooked up to six LEDs. As I'm verifying, errors keep coming up and it is saying certain things are not declared, but they are. My professor does not know how to fix it either. Here is a copy of the sketch so far, if someone could look at it, maybe you can tell me what the problem is? Thank you!
(code tags added by moderator)
Code:
  Button
 Turns on and off a light emitting diode(LED) connected to digital
 pin 13, when pressing a pushbutton attached to pin 2.
 The circuit:
 * LED attached from pin 13 to ground
 * pushbutton attached to pin 2 from +5V
 * 10K resistor attached to pin 2 from ground
 * Note: on most Arduinos there is already an LED on the board
 attached to pin 13.
 created 2005
 by DojoDave <http://www.0j0.org>
 modified 30 Aug 2011
 by Tom Igoe
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/Button
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 8;     // the number of the pushbutton pin
int timer = 200;           // The higher the number, the slower the timing.
int ledPins[] = {
  2, 7, 4, 6, 5, 3 };       // an array of pin numbers to which LEDs are attached
int pinCount = 6;           // the number of pins (i.e. the length of the array)
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
int thisPin;
  pinMode(buttonPin, INPUT);
  // the array elements are numbered from 0 to (pinCount - 1).
  // use a for loop to initialize each pin as an output:
  for (int thisPin = 0; thisPin < pinCount; thisPin++)  {
    pinMode(ledPins[thisPin], OUTPUT);
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // start array:
    digitalWrite(ledPins[thisPin], HIGH);
  // loop from the lowest pin to the highest:
    // turn the pin on:
    delay(60);
    // turn the pin off:
    digitalWrite(ledPins[thisPin], LOW);
  // loop from the highest pin to the lowest:
  for (int thisPin = pinCount - 1; thisPin >= 0; thisPin--) {
    // turn the pin on:
    delay(250);
  else {
    // stop array:
    digitalWrite(ledPin, LOW);
« Last Edit: March 13, 2013, 12:18:27 pm by CrossRoads » Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
move this
int thisPin;
to the declarations area, that makes it usable anywhere in the program,
and stop re-declaring it else where, such as:
for (int thisPin = 0; ...
Also, please use the code tags ( # sign ) when posting code.
« Last Edit: March 13, 2013, 12:19:47 pm by CrossRoads » Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
This part
// stop array:
ledPin is not defined anywhere. If you mean to write the whole ledPins array LOW, you have to do it in a loop.
Logged
Pages: [1]   Go Up
Print
Jump to:
